302 ID
Old Sep 19, 2002 | 08:24 PM
LaDANO's Avatar
LaDANO
302 ID
trying to date my 302 #'s are EOAE and below that is D3C. I changed the rear main seal, had to match it up 1 piece '85. I thought this was an '80 but no 1 piece in '80 please help. I'm trying to get the right balancer and flex plate to cast out the vibration below 1200 rpm's.
Old Sep 19, 2002 | 09:39 PM
Franklin2's Avatar
Franklin2
302 ID
If it's the one piece rear main seal block, you definitely need the late model 50oz inbalance flywheel/flexplate and probably the late model front damper too.
Old Sep 20, 2002 | 12:06 AM
desperado_18_2000's Avatar
desperado_18_2000
302 ID
If that code is correct it is a 80 model 302. the entire code should read E0AE-6015-D3C. if you got the code from above the starter it should read this, or something similar. i don't belive that the 80 model 302's had a balance change, i don't think the 302 changed balance till 82. up until the i belive it was a 28 oz imbalance like the 351w's not sure though, keep us posted.
Old Sep 20, 2002 | 01:50 PM
teschwab's Avatar
teschwab
302 ID
Ordnance
Sep 3, 2014 01:53 AM
shore
1978 - 1996 Big Bronco
Nov 14, 2013 12:01 AM
70blue
Apr 27, 2007 07:53 PM
towrig302
Sep 3, 2004 10:58 PM
daerhldgs2
Dec 29, 2003 10:02 AM
