older heads
Old Dec 28, 2003 | 09:38 AM
daerhldgs2's Avatar
daerhldgs2
older heads
I recently picked up a 302 in pieces and wonder if anyone knows about heads from 68 -302 with casting # C80E , I've found C80Z in ref. books and assume the others are similar anyone know? The block was setup for a roller cam and has XXX cast into the lifter valley area. any idea if this means anything?BTW the block is from the 80s.
thanks
Old Dec 28, 2003 | 10:33 PM
pinellas50's Avatar
pinellas50
The XXX on the block means it is a roller motor like those found in the HO Mustang and Lincoln LSC. I don't know about the heads.
Old Dec 29, 2003 | 05:35 AM
RTM's Avatar
RTM
There is nothing special about 68 heads. If yo used them the would need hardened valve seats installed and you would have to measure for the correct push rod length if you used them on the roller block. They also have an adjustable rocker arm and late models heads do not.
Old Dec 29, 2003 | 10:02 AM
daerhldgs2's Avatar
daerhldgs2
I believe the 68 heads have 52.5 cc. combustion chambers which are quite a bit smaller than newer heads. Give me a point or so increased comp. and since I run propane that helps. I like th eadjustable rockers and will use the heads with valve seats as is for a few years and when they go I'll rebuild the heads. thanks for the input
ryankrizan
Jul 27, 2011 06:00 AM
the Canadian
Oct 14, 2010 09:50 PM
gearhed1971
Jan 30, 2009 03:25 PM
frinkseth
Oct 12, 2004 06:51 AM
4294x4
Sep 12, 2000 07:49 PM
