fuel line recomendations
They are a high pressure, high heat line as I understand it. Some of the members have found substitute hose but I don't know what it is or where they get it. And you just hope that it don't fail.
Ford is probably the easiest and quickest, that's where I got mine when I changed my fuel pump.
Good luck
Rog
Good luck
Rog
FUEL HOSES <?xml:namespace prefix = o ns = "urn:schemas-microsoft-com
ffice
ffice" /><o
></o
>Fuel Hose, BLUE (Aeroquip FC498-06)
(Ford) F4TZ-9324-CA, 3" Long lift pump to filter inlet
(Ford) F4TZ-9324-DA Shorter than above, Filter outlet to High Pressure (piston) pump inlet<o
></o
><o
></o
>Aeroquip FC332-06 or FC498-06 , 3/8" rated 250 psi, 17 bar. Same thing that ford will sell you in little packages, cost sky high. You need 3 little aeroquip hoses - 2 about 1 3/4" and one shorter, - the 1 3/4 " hoses are ford part # F4TZ-9324-CA , the part # on the shorter hose F4TZ-9324-DA.<o
></o
>You can use anything else that meets SAE J30R9 specs.
