91 Explorer Problems
Old Mar 31, 2008 | 04:14 PM
sandersb's Avatar
sandersb
I was driving home the other night and smoke began to billow out from under my hood. This is the source of the smoke...and smell. I don't know what part this is can anyone help me out please? Thank you in advance.
Since a picture is worth 1000 words -
Old Mar 31, 2008 | 04:25 PM
5.0B2's Avatar
5.0B2
air conditioning compressor (the front part with the serpentine belt around it is the air conditioniing clutch)
Old Mar 31, 2008 | 05:13 PM
Bear River's Avatar
Bear River
Former ******
Looks like your compressor has seized up and the belt is slipping and burning. You will need to repair the AC system. A failed compressor is not something you can do yourself, and the AC system has to be properly flushed and cleaned out. Its either fix it, or you will have to disable and bypass the AC system.
Old Apr 1, 2008 | 05:43 AM
marragtop's Avatar
marragtop
You can bypass the compressor by getting a non AC 4.0 belt. IF you are going to fix the AC, you may need to consider converting to R134a if you are still at R12.
Old Apr 1, 2008 | 09:45 AM
sandersb's Avatar
sandersb
Thanks for the responses guys. It doesn't sound like an undertaking that I'm capable of so it's off to my friendly local mechanic.
Old Apr 1, 2008 | 10:04 AM
marragtop's Avatar
marragtop
If you don't care about the AC, just have the mechanic bypass the compressor by using a shorter belt. Parts and Labor for that should be around $70. If you want the AC fixed it will be probably be quite a bit more. Good luck.
4x4countryboy
Apr 29, 2012 04:32 PM
xc4jokestomper
Jul 18, 2011 10:43 AM
2001400ex
Mar 12, 2010 08:19 PM
crescentwrencher
May 7, 2008 10:23 PM
weldingfreak
Feb 12, 2006 03:10 PM
