Anyone using Ford Racing performance cams?
Old Sep 26, 2002 | 07:48 AM
jwtaylor's Avatar
jwtaylor
I cam across some ford racing cams in a book and well the 65 dollar price tag was right and the specs and duration where close to other cams. I was looking at the for-m-A332 cam that had a int. lift of .472, exh. .496 the int. duration was somewhere around 214 and exh. was around 220 so I figure it should work fine in a 351 ford 2wd truck. Anyone happen to run this or a similar one. Thank you for your time
Old Sep 26, 2002 | 10:39 AM
teschwab's Avatar
teschwab
i have used the earlier 302 version for ten years in a old falcon hot rod. the # a312 is the same cam with the exception of having the early 289/302 firing order. the cam you mentioned #a332 will perform well in your 351. the cam is a split pattern cam and will perform well up to 6000 rpm. install the cam straight up. they also offer the little brother to the a332 and it performs real well down low. i am currently using the smaller cam in a 302/c6 powered f100. the idle will be nice while at the same time it will talk to you. have fun
Old Sep 28, 2002 | 07:30 AM
jwtaylor's Avatar
jwtaylor
Appreciate the reply. Sounds like I am on track with this cam.
Old Sep 29, 2002 | 06:14 PM
HotWhlz85's Avatar
HotWhlz85
Boss50
Mar 17, 2013 09:51 PM
mustang81
19
Jan 23, 2013 09:14 PM
jwtaylor
Aug 31, 2003 04:11 PM
brucen2son
Jan 13, 2003 12:08 AM
