Offroad & 4x4
shifter play
Old Mar 30, 2008 | 06:14 PM
ride2die's Avatar
ride2die
shifter play
Hey guys, My 89 f150 5 speed gots a 4in suspension lift and a 2in homemade body lift. but I've been having problems with the shifter. It has ALOT of play and the shifter lifts up and down. I dont now whats wrong. I really need some help.
Old Mar 30, 2008 | 06:17 PM
quadzjr's Avatar
quadzjr
just another Rockwell looser
oh this is going to be good......
curious, whadja make it out of?
Old Mar 30, 2008 | 06:18 PM
ride2die's Avatar
ride2die
steel pipe with bushings
Old Mar 30, 2008 | 06:21 PM
quadzjr's Avatar
quadzjr
cool!
Old Mar 30, 2008 | 06:22 PM
chrono4's Avatar
chrono4
oh wow.... any pics of the truck?
And what shifter, the t case or tranny?
Old Mar 30, 2008 | 06:24 PM
ride2die's Avatar
ride2die
no sure on the tranny but t-case warner1345
Old Mar 30, 2008 | 06:26 PM
chrono4's Avatar
chrono4
I meant which shifter is having the problems?
Old Mar 30, 2008 | 06:27 PM
ride2die's Avatar
ride2die
tranny my bad
Old Mar 30, 2008 | 06:28 PM
bad96's Avatar
bad96
hey ride2die im still a newbie too but a homemade body lift????? asking for trouble with this thread!!!!!!
Old Mar 30, 2008 | 06:32 PM
ride2die's Avatar
ride2die
Well it was happening before I put the lifts on too.
Old Mar 30, 2008 | 06:36 PM
STGFordCrazy04's Avatar
STGFordCrazy04
Very fitting username!
Please tell me that at minimum you welded washers or a plate with a hole to the top and bottom and you dont have a piece of pipe wallowing around a grade 2 bolt.
Anyway...
I doubt your body lift is causing your transmission trouble. Maybe post in the transmission forum. You probably have a zf 5speed.
Old Mar 30, 2008 | 06:38 PM
quadzjr's Avatar
quadzjr
Anyway...
isn't it a M5OD? or maybe not....idk
Old Mar 30, 2008 | 06:39 PM
ride2die's Avatar
ride2die
K thanks... Oh yes I did weld washers too.
bad96's Avatar
bad96
not rippin yur body lift just saying ya need to back it up with using the good stuff and evn still body lifts arent gonna go over well!!!!
Old Mar 30, 2008 | 06:48 PM
STGFordCrazy04
M5OD were put in rangers
