Cleaning motor
Old Mar 30, 2008 | 05:43 PM
reifwj's Avatar
reifwj
Cleaning motor
what's the easiest way to clean the outside of a greasy motor. I was told to use Easy Off oven cleaner, put won't that eat the gaskets? I have the engine on a hoist right now.
Old Mar 30, 2008 | 06:46 PM
gezn2's Avatar
gezn2
Yeah, I'd be leery of Easy Off on an assembled motor, it's *great* on old gaskets and baked on crud with loose parts
If you'e careful with the overspray a power-washer will do a decent job, used car lots do it every day......
Old Mar 30, 2008 | 07:18 PM
reifwj's Avatar
reifwj
doesn't it have to be sealed
Old Mar 30, 2008 | 07:48 PM
waynaferd's Avatar
waynaferd
pressure wash it outside
Old Mar 30, 2008 | 08:59 PM
Ford_Six's Avatar
Ford_Six
stuff rags in the exhaust ports, and don't spray straight at them. Use a dust cover on the carb if it's still mounted, or use a block off plate on an open intake, then soak it with Simple Green and power wash or steam it.
Old Mar 30, 2008 | 09:58 PM
46069dord's Avatar
46069dord
i would think steam would be the best it might not be faster but i would steam mine if it was out.
Old Mar 30, 2008 | 10:06 PM
reifwj's Avatar
reifwj
how does a person steam it? Thanks
Old Mar 30, 2008 | 10:39 PM
46069dord's Avatar
46069dord
you can buy them i think lows sells them.
Old Mar 30, 2008 | 11:00 PM
Ford_Six's Avatar
Ford_Six
Rent a diesel fired steam cleaner from a company like United Rentals. A good steam pressure cleaner would cost a minimum of $1500 for a USED one.
I stumbled across one that needed to be rebuilt from the ground up, and it gets it's fair share of use around here.
Old Mar 31, 2008 | 01:50 AM
Fritolay's Avatar
Fritolay
ive always just used a couple of cans of gunk's engine brite you spray the stuff on let it sit for 15 minutes then wash it off you can just use a regular hose it works very well. just make sure all ports are blocked off coolant passages exhaust ports and intake.
Old Mar 31, 2008 | 07:33 PM
baitmaster's Avatar
baitmaster
car wash
I have taken a few to the car wash with a can of gunk. It is messy, but does a good job. Also Gunk and a hose with a good nozzle works too.
Old Mar 31, 2008 | 09:08 PM
scrapyardking's Avatar
scrapyardking
I always use a puty knife for the caked on stuff the use keroseen and a brush.
Old Apr 1, 2008 | 05:51 PM
seven up's Avatar
seven up
i've been using a putty knife for the heavy stuff.
a coffee can of diesel fuel and wire brush for other stuff.
Old Apr 2, 2008 | 10:19 AM
qman's Avatar
qman
use Simple Green. I bought a gallon of the undiluted stuff at AZ. The jug tells you how to dilute it based on what you're trying to clean. You spray it on and blast it with the hose. It took 2-3 rounds of doing this but it got off just about everything. Plus, your truck smells pretty for a long time.
