Pinstripe
My 2008 F-350 truck is white with gold bottom. The pin strip between the two paint colors is black and gold. I found the 2003 150 Lariat had a thick double pin strip and lariat script in very, very, dark green and same gold color as the 2008. The dark green is so dark that it is black. Just what I wanted. The F-150 pin strip goes from near the front of front fender, along about 3" below the top of the fender to just 3" behind entry door. The word Lariat is centered over the Super Cab rear door. Now I don't have a large white slab side as the new pin striping has broken it up. The Ford part number from Brookings Harbor Ford in Brookings, OR is XL3Z-1820000-AAB and XL3Z-1820001-AAB. This will help you find the stripe. Check out 2000 to 2003 F-150 Lariats to hopefully find the color you need.
The ford stripe kit detail I gave you only runs to either 3" behind the front door on the SC or 3" into box behind the rear King Crew cab. The list price was $91.71 for each side. Also remember the gold color became deeper in about 2004 and then returned to the lighter Pueblo Gold that was used in the earlier 2000 to 2003 F-150's. The color on the 2003 pinstripe I used was a perfect match with the 2008 Pueblo Gold.
The very, very dark green will show black. When you order the ford stripe numbers I listed for you, the order details in the Ford computer will warn you that the deep green will appear black. That it does.
