just bought and one possible problem
Old Mar 29, 2008 | 04:39 PM
mxer0022's Avatar
mxer0022
Thumbs up just bought and one possible problem
ok i just bought an '06 cc sb 6.0L psd last night and when i got under it today while it was light out i noticed that the front pinion seal on the rear diff is leaking. it this something that is relatively easy to fix on my own or should i concider taking it to the dealership?
Old Mar 29, 2008 | 04:50 PM
bismic's Avatar
bismic
The warranty follows the truck, not the owner. You should take it to the dealer if it is still under warranty.
Old Mar 29, 2008 | 05:05 PM
mxer0022's Avatar
mxer0022
unfortunately the truck has 49,000 miles on it and is out of the 3 yr 36,000 warranty.
Old Mar 29, 2008 | 05:21 PM
bismic's Avatar
bismic
Sorry to hear that. Hopefully someone will come along w/ the answer on doing it yourself. You also might look for it in the workshop manual. Below is a link to an on-line manual. Enjoy
<TABLE style="WIDTH: 607pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=809 border=0 x:str><COLGROUP><COL style="WIDTH: 607pt; mso-width-source: userset; mso-width-alt: 29586" width=809><TBODY><TR style="HEIGHT: 15.75pt; mso-height-source: userset" height=21><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 607pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 15.75pt; BACKGROUND-COLOR: transparent" width=809 height=21>http://www.motorcraftservice.com/pubs/content/~WS6O/~MUS~LEN/20/S6OLEFT.HTM</TD></TR></TBODY></TABLE>
Old Mar 29, 2008 | 05:40 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
Mark, you amaze me with all of your info and links to help members! Keep up the good work and thank YOU! I tried to give you some rep points but I need to spread some more before you get some more.
Old Mar 29, 2008 | 05:55 PM
bismic's Avatar
bismic
Thanks D8 - it keeps me out of the bars at night!
Seriously - MOST of the info comes from other folks and past posts from this site. I just decided some time ago to try to catalogue it so I could get to it quickly.
For example - In the case of the post above - thank Ozx3+1!
Old Mar 29, 2008 | 06:25 PM
06F250XLTFX4's Avatar
06F250XLTFX4
i just had the same problem with my 2006. mine was covered under warranty (25,000 on the truck) the dealership fix the problem in a hour. from what i can tell from the tech write up it is a simple fix. "REMOVED REAR DRIVESHAFT. REMOVED PINION FLANGE, REMOVED AND REPLACED PINION SEAL. CLEANED AREA. TOPPED OFF REAR AXLE FLUID. REINSTALLED DRIVESHAFT." That is what was writen on the service invoice. The tech also did standard inspection of the tires, battery, and other stuff.
hope this helps. And enjoy your new truck.
Old Mar 29, 2008 | 08:14 PM
mxer0022's Avatar
mxer0022
i was hoping that it would be easy like that. i mean i have changed them before but i have never owned anything this new or of this caliber so i just wanted to check so that i didn't get in over my head with having to purchase any special tools and what not. thank you all for your words of wisdom. i am sure that i will have plenty more questions later on down the line! i honestly don't know what i would do without this place!
Old Mar 29, 2008 | 08:23 PM
bismic's Avatar
bismic
From the workshop manual link I supplied (in case you didn't look):
<TABLE cellSpacing=0 cellPadding=3 width="50%" border=1><CAPTION>Special Tool(s)</CAPTION><TBODY><TR vAlign=top><TD></TD><TD vAlign=top>2-Jaw Puller
205-D072 (D97L-4221-A) or equivalent </TD></TR><TR vAlign=top><TD></TD><TD vAlign=top>Installer, Drive Pinion Flange
205-233 (T85T-4851-AH) </TD></TR><TR vAlign=top><TD></TD><TD vAlign=top>Holding Fixture, Drive Pinion Flange
205-126 (T78P-4851-A) </TD></TR><TR vAlign=top><TD></TD><TD vAlign=top>Installer, Drive Pinion Oil Seal
205-208 (T83T-4676-A)</TD></TR></TBODY></TABLE>
<TABLE cellSpacing=0 cellPadding=3 width="50%" border=1><CAPTION>Material</CAPTION><TBODY><TR vAlign=top><TH>Item</TH><TH>Specification</TH></TR><TR vAlign=top><TD>Premium Long-Life Grease
XG-1-C or XG-1-K (Canada CXG-1-C)</TD><TD align=middle>ESA-M1C75-B</TD></TR><TR vAlign=top><TD>Motorcraft SAE 75W-140 High Performance Rear Axle Lubricant
XY-75W140-QL (vehicles with the trailer towing option or 4:10 ratio)</TD><TD align=middle>WSL-M2C192-A</TD></TR></TBODY></TABLE>
Removal
  1. CAUTION: The color on the rear face of the drive pinion nut is critical to this repair. Use the same color new drive pinion nut for installation. If a new collapsible spacer must be installed for pinion bearing preload reduction, install the nut supplied with the new spacer kit or damage to the component may occur.
    NOTE: The rear wheels and brake calipers must be removed to prevent brake drag during drive pinion bearing preload adjustment.
    Remove the rear brake calipers. For additional information, refer to Section 206-04.
  1. Remove the driveshaft. For additional information, refer to Section 205-01.
  1. Install a Nm torque wrench on the pinion nut and record the rotational torque required to maintain rotation of the pinion through several revolutions.
    1. CAUTION: After removal of the pinion nut, discard it. A new nut must be used for installation.
      Using the special tool, hold the pinion flange while removing the pinion nut.
      1. Mark the pinion flange in relation to the drive pinion stem to make sure alignment is correct during installation.
        1. Using the special tool, remove the pinion flange.
          1. Force up on the metal flange of the rear axle drive pinion seal. Install gripping pliers to the seal flange and strike with a hammer until the rear axle drive pinion seal is removed.
            Installation
            1. Lubricate the new pinion seal with clean premium long-life grease.
            1. CAUTION: If the rear axle drive pinion seal becomes misaligned during installation, remove the rear axle drive pinion seal and replace it with a new seal.
              Using the special tool, install a new rear axle drive pinion seal.
              1. Lubricate the pinion flange splines with clean synthetic rear axle lubricant.
              1. NOTE: Disregard the scribe marks if a new pinion flange is being installed.
                Align the pinion flange with the drive pinion shaft.
                1. With the pinion flange in place in the rear axle housing, use the special tool to install the pinion flange.
                  1. Select the correct pinion nut for installation.
                    <TABLE cellSpacing=0 cellPadding=3 border=1><CAPTION>10.5 In. Full Float Drive Pinion Nut </CAPTION><TBODY><TR><TH vAlign=bottom align=middle>Part Number</TH><TH vAlign=bottom align=middle>Color Description</TH><TH vAlign=bottom align=middle>Application</TH></TR><TR><TD vAlign=top align=middle>19G405</TD><TD vAlign=top align=middle>Blue</TD><TD vAlign=top align=middle>Axles built before 7/16/07</TD></TR><TR><TD vAlign=top align=middle>4320</TD><TD vAlign=top align=middle>White</TD><TD vAlign=top align=middle>Axles built after 7/16/07</TD></TR><TR><TD vAlign=top align=middle>4C121</TD><TD vAlign=top align=middle>White</TD><TD vAlign=top align=middle>Kit with spacer for all 266.7 mm (10.50 in) axles</TD></TR></TBODY></TABLE>
                  1. CAUTION: Install a new pinion nut with the same color as the original if not replacing the collapsible spacer or damage to the component may occur.
                    Install the new washer and pinion nut. Only hand-tighten the pinion nut at this time.
                  1. CAUTION: Do not loosen the pinion nut to reduce drive pinion bearing preload. Install a new drive pinion collapsible spacer and pinion nut if drive pinion bearing preload reduction is necessary. If a new collapsible spacer must be installed for pinion bearing preload reduction, install the nut supplied with the new spacer kit or damage to the component may occur.
                    Using the special tool to hold the pinion flange, tighten the pinion nut to set the drive pinion bearing preload.
                    • Tighten the pinion nut, rotating the pinion occasionally to make sure the drive pinion bearings are seating correctly. Take frequent drive pinion bearing preload readings by rotating the drive pinion gear with a Nm (lb-in) torque wrench. The final readings must be 0.56 Nm (5 lb-in) more than the initial reading taken during removal.
                  1. Install the driveshaft. For additional information, refer to Section 205-01.
                  1. Install the brake calipers. For additional information, refer to Section 206-04.
                  Old Mar 29, 2008 | 08:41 PM
                  mxer0022's Avatar
                  mxer0022
                  i did see that and i bookmarked the link. that thing is full of information! thank you for sending that too me! i will put it too good use!
                  Old Apr 1, 2008 | 08:08 AM
                  Headviking's Avatar
                  Headviking
                  Do you have a link for a 2007 SD?
                  Thanks
                  Old Apr 1, 2008 | 09:48 PM
                  bismic's Avatar
                  bismic
                  <TABLE style="WIDTH: 607pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=809 border=0 x:str><COLGROUP><COL style="WIDTH: 607pt; mso-width-source: userset; mso-width-alt: 29586" width=809><TBODY><TR style="HEIGHT: 15.75pt; mso-height-source: userset" height=21><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 607pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 15.75pt; BACKGROUND-COLOR: transparent" width=809 height=21>http://www.motorcraftservice.com/pubs/content/~WS7O/~MUS~LEN/20/S7OLEFT.HTM</TD></TR></TBODY></TABLE>
                  2007 Manual
                  Old Apr 2, 2008 | 08:41 AM
                  gonnasellit_temp's Avatar
                  gonnasellit_temp
                  Great info! My 03 also has a pinion seal leak which I need to fix (replaced by dealer at 4000 mi and leaking again!). Is the info you supplied the same for an 03 or is their a better link?
                  Old Apr 2, 2008 | 03:25 PM
                  04F250PSD's Avatar
                  04F250PSD
                  You say youjust purchased the Truck, was it from a dealership? If it was I would think they would fix it being how you just purchased it the day before. I would ask anyway before I would fix it.
                  Old Apr 2, 2008 | 04:13 PM
                  OZX1's Avatar
                  OZX1
                  Sharing the love!
