auto to manual
Old May 21, 2008 | 01:39 PM
86Stepside's Avatar
86Stepside
The mazda trans is usually reffered to as the m5od. F250's can have 300's too, the one I found my zf in was one, 300, 302, 351 all have the same bellhousings.
Old May 21, 2008 | 02:02 PM
85e150's Avatar
85e150
Pics of the trans. You'll see it when you find one or the other:
Domestic Truck Tranny Guide
I'm more with Raider50 on this one. Brakes alone are reason enough to upgrade if heavy loads are in the future.
As for a 300 out pulling a 351, go find a hp/torque chart for the 351 and explain how that would be possible.
Good luck with your project.
Old May 21, 2008 | 02:03 PM
tjthegreat's Avatar
tjthegreat
usually m5OD
Old May 21, 2008 | 05:38 PM
tjthegreat's Avatar
tjthegreat
it is possible because the 300 has more low end grunt than the 351 does,the 351 tops out at a higher rpm
Old May 21, 2008 | 10:04 PM
Raider50's Avatar
Raider50
Oh alright i was thinking you were talking about numerous tons here. I was thinking when they put a ton and a half of coal in the bed of my 3/4 ton it squatted down fairly low, i was going to be thinking that if you were going to be packing around ton's of weight you might want to think about getting a suspension upgrade also.
Old May 22, 2008 | 02:18 PM
ssidney's Avatar
ssidney
the 300 does NOT have more low end. I have one of each and it's not even comparable, yes the one in my sig. has 4.10 gears but previous to that I had an '87 f-150 3.55 with the 351 as well and it could out-pull the 300....the only reason I have the L6 is because of the fuel mileage.
Old May 22, 2008 | 03:37 PM
jas88's Avatar
jas88
From my 1990 Ford F-Series brochure:
300 Six = 150 HP @ 3400 RPM, 260 LB/FT @ 2000 RPM
351 V8 = 210 HP @ 3800 RPM, 315 LB/FT @ 2800 RPM
From the torque curve published therein, it looks like the 351 makes about 300 LB/FT @ 2000 RPM so I don't see how you could say the Six has more "grunt" than the 351.
Old May 22, 2008 | 04:41 PM
Raider50's Avatar
Raider50
or you could just get a 460 and be able to tow anything you can hook onto
Old May 22, 2008 | 06:16 PM
tjthegreat's Avatar
tjthegreat
hmm thats interesting ive heard all over this site that the inline six has more torque till about 2400 rpm while the 351 kepps going,hell look at a cummins compared to the pws,you may be right if any of you kno any dyno websites with these engines can u let me kno,sidney i bet a big reason ur 351 pulled ur 6 is because it is a 250
Old May 22, 2008 | 07:00 PM
icrman's Avatar
icrman
So how come my owner manual says the truck can pull more with an automatic than the manual transmission? I would hate to have to start out on a hill with a 14k trailer with a manual trans.
Old May 22, 2008 | 08:12 PM
ssidney's Avatar
ssidney
the 351 in my 250 came out of my '87 150 (thats why it's no longer in my sig)....the difference is not small either...like comparing an arab to a clydesdale
Old May 22, 2008 | 08:13 PM
ssidney's Avatar
ssidney
the automatic gives you tq multi in the tq converter
Old May 23, 2008 | 08:50 AM
  #28
alxsnmr's Avatar
alxsnmr
Honestly, numbers do not lie but people will get rather passionate about objects. What engine you use to do the work with is up to the individual but if someone is satisfied with the ablity of a particular engine why encourage them to upgrade? If they are unsatisfied and seeking more power for the work then I can see encouraging upgrading the engine/drivetrain/truck. I am certainly happy with my 351 in my bronco, and would be much happier of my 78 pickup had a running engine.
brian1985f150
Jul 12, 2011 03:48 PM
fordinmudd
Offroad & 4x4
32
Aug 11, 2005 10:00 PM
payner22
May 20, 2005 09:00 AM
bulldogcountry1
Jan 23, 2003 04:57 PM
