Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Escape knocking 2005
Old Jan 24, 2011 | 11:40 AM
reboswon's Avatar
reboswon
Red face Escape knocking 2005
I have a ford escape 2005 w/2.3 litter 4 cyl. front wheel drive. 75,000mi. sometimes knocks at start up. Knocks if i let off the gas durring exceleration. just started to notice a knock at steady speed on the interstate. if i give it gas i will stop or if i let off the gas it will stop. Any thoughts.....
Old Jan 24, 2011 | 01:00 PM
wptski's Avatar
wptski
That normally indicates looseness somewhere. A single knocking sound?
Old Jan 24, 2011 | 01:29 PM
reboswon's Avatar
reboswon
I first heard it when i would let off the gas when exceleration. The knock or tapping is very uniform. to me it sounds like a rod knock? something like diesel knock
Old Jan 24, 2011 | 06:31 PM
70f100longbed's Avatar
70f100longbed
How has it been maintained? The 2.3 cannot tolerate lack of maintance and will spin rod bearings. When that happens the piston hits the cylinder head. The rods dont have any locks for the bearings so the only thing keeping them from spinning is interference fit. Take the oil filter off and see if any metal is in it.
Old Jan 24, 2011 | 08:35 PM
reboswon's Avatar
reboswon
Not maintained well
Old Jan 24, 2011 | 08:37 PM
reboswon's Avatar
reboswon
Not maintained well... What can be done if this is the case? How much can it cost?
Old Jan 25, 2011 | 06:26 AM
tomw's Avatar
tomw
How much do you have? You can get a used engine or a re-manufactured short or long block or have yours repaired. A used engine, depending on age and mileage, can run from a few hundred dollars to near a thousand. A re-manufactured will cost more as more new parts are used in the assembly, and they guarantee their product for more than a short time. A short block does not include the cylinder head, and you are expected to use the old one. A long block includes the cylinder head.
The labor cost for the replacement is just about the same for used or re-manufactured, unless the head needs to be transferred or re-worked. Figure a full days labor spent removing and installing. If you know wrenches and have access to a hoist, you can possibly do the R&R yourself.
tom
85lebaront2
4 Cylinder Engines
Oct 30, 2016 09:49 AM
shanesluck
Sep 6, 2015 12:55 PM
Zack12
38
Aug 10, 2015 02:47 PM
Cedave
May 17, 2014 08:19 PM
mlytc
Nov 18, 2013 10:48 AM
