Stroker 393 question
Old Dec 8, 2001 | 08:38 AM
mnm1997's Avatar
mnm1997
Old Oct 23, 2002 | 11:45 AM
4x4akvan's Avatar
4x4akvan
What piston should I use with stock 85 HO heads? I want to keep it around 9.5 to one. I'm going to use this motor in an RV and don't think I need high dollar pistons like KB or Probe. Is there a stock 302 dish that would work? I don't know what the cc is of th stock 85 HO heads on my 351W.
Old Oct 23, 2002 | 01:06 PM
lvmoose007's Avatar
lvmoose007
I think I would at least get a hypereutectic for it, there are increased side loads with this setup and I am not sure a cast piston would be up to the task. I think there is a compression calculator somewhere around this site. I would not use the HO heads that you are thinking of using. The only difference between the HO and regular windsor is the cam (I think compression is higher but nosure, do not have any info in front of me) and the intake manifold. The head has the same size ports and valves as a 289 or 260 head and those heads are too small for even a 260. Step up to a gt40p($500.00, bolt-on) head and you will get a great responding engine that is still within a decent budget(especially if you have the HO heads rebuilt properly, the cost will be close to the gt40p heads.
Old Oct 24, 2002 | 04:24 PM
pcmenten's Avatar
pcmenten
I believe that the cc's of a E5TE head are 65 cc's. I, too, would encourage the use of hypereutectic pistons. Also, I would encourage you to make sure the engine is zero decked and that the head gasket is not too thick (.038" is good).
Old Oct 24, 2002 | 06:12 PM
4x4akvan's Avatar
4x4akvan
OK thanks for the advise. What is ment by zero decking and what is the proper way to do it.
Old Oct 24, 2002 | 06:42 PM
pcmenten's Avatar
pcmenten
'Zero deck' is where the top of the piston is flush with the top of the cylinder case (block). Really and truly flush. If it is .020" below deck that will effect how the engine operates. It is not uncommon to find pistons as much as .060" below deck.
The reason to do this is to benefit from the quench built into those heads. Although they don't have as much quench as the E6SE heads (or 351 C9AE, or 289 C6OE, or F7TE/GT40p heads), they do have quench and your engine will tolerate higher compression better with zero deck and quench.
Old Oct 24, 2002 | 07:38 PM
pcmenten's Avatar
pcmenten
I meant to add that your machinist is the one to zero deck your engine. There are many ways to do it but he'll probably just cut the tops of the cylinder case. It cost me $150 to have my 292 zero decked.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
