Sponsored by: Real Truck
Is It Worth It??
Old Mar 27, 2008 | 11:16 PM
emik26's Avatar
emik26
Is It Worth It??
Gentlement I need some help. I really really want a new F-250. I currently have a F-150 that is going to have to go if I get a new 250. I am wondering if there will be a difference in gas mileage when I haul my trailer. I haul a 7x16 trailer that averages about 6000lbs as far a weight. In my F150 I usually get about 7 to 8 miles per gallon on the highway. Will having a F250 be worth getting? Will it save me any money in the long run? Help me out guys. If it is not going to make that big of a difference I want to know. Tell me what you think. Positive or negative. Thanks for your help all.
Old Mar 27, 2008 | 11:20 PM
Momorris's Avatar
Momorris
Are you looking at a diesel? Diesels are known for their ability to get good fuel mileage with in tow. With that load and a reasonable speed I would expect 12 mpg on the interstate. How often do you tow? That is the determining factor.
Old Mar 27, 2008 | 11:24 PM
Dave S's Avatar
Dave S
What Momorris said! The 5.4 will work, but mileage won't be there. You'll wind up not much better than you are now. The V-10 might work better, but you'll suffer if you aren't pulling the trailer. The Clean-Air Converter (Diesel ) would be your best bet if you pull regularly.
What would help is to know the type of use your truck will see, and you driving style, too. Those are the main factors!
Old Mar 27, 2008 | 11:51 PM
emik26's Avatar
emik26
I pull the trailer about a half dozen or so times a month. Besides that I would like a big truck and deck it all out with all the after market parts and options. When I am not hauling I dont really drive my truck alot. Maybe 50 miles a week tops. When it comes to hauling though it is killin me in gas. I know diesel is more expensive now than gas but if I will get more gas mileage then it might be worth it.
Old Mar 28, 2008 | 07:49 AM
Izzy351's Avatar
Izzy351
Yep -- you're in the perfect position to benefit from a diesel. I don't even tow with mine, and I love it!! I wanted to upgrade to a full-size truck, and now I have one that gets the same mileage as my Ranger!!
You should get about twice that mileage with a diesel. That little bit of load will be like nothing's there. I pulled my Dad's 5500 lb. boat and it felt like an empty trailer.
Old Mar 28, 2008 | 07:55 AM
elee3's Avatar
elee3
Are you looking to buy a new truck or pre owned? The reason I ask is because, if you are looking at diesels, the new 6.4 is not known for getting good mileage.
Old Mar 28, 2008 | 10:25 AM
cc322's Avatar
cc322
07 and later Diesels simply don't get the same fuel economy as the pre emissions smothered engines.
Fact, with the price of fuel well exceeding premium gas unless you need to work a 07 and later diesel on a regular basis it's simply not practical owning one. And God forbid owning one when the warranty expires...you better have deep pockets to pay the diesel techs that can't even figure out these new over complicated fuel guzzling beasts.
__________________
Basically, unless you put huge miles on a diesel truck, you will not recoup the cost of the increased initial purchase price. But....ya can't argue with that diesel torque.
Old Mar 28, 2008 | 10:34 AM
redford's Avatar
redford
FTE Leadership Emeritus
You don't need a diesel. A 5.4L V-8 will pull the load just fine, a V-10 even better.
When I pull my trailer (pictured) with my 5.4L V-8, I get 8.5-10.5 MPG, depending on loaded weight. My trailer weighs 3500 pounds empty. With 4000 pounds in the trailer (7500 gross) I get around 9 MPG.
Aerodynamics play a huge part in mileage. Towing my trailer empty but with my hard tonneau cover on the truck, I get 7.5-8.5 MPG. If I remove the bed cover, but no other changes, my mileage goes jumps to 10-10.5 MPG. If, at this point (no bed cover) I remove the tailgate, mileage drops to back down to around 8 MPG.
Old Mar 28, 2008 | 04:52 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
This might be a good time to wheel-and-deal on a diesel since they're probably not selling many of them due to higher fuel prices. Just my .02
Old Mar 28, 2008 | 05:08 PM
swaybar's Avatar
swaybar
1/2 tons are good and do a suitable job for work BUT you will love the differance in a 3/4 or even one ton. everythings a little bit bigger and stronger. there's a differant feel in the suspension-a stronger more confident feel. cause it really is. everythings tighter and heavier. i remember when i went from a half ton to a three quarter ton-it was an awesome feeling. you'll love it. gas is going to be pretty much the same. if you can (diesels) the way to go.
Old Mar 28, 2008 | 05:09 PM
mastercaster's Avatar
mastercaster
with a mid weight load like that, a gasser would likely serve you fine. now the F250 (gas or diesel) and up will handle the load much better. if you were working it harder and towing heavier, i'd say spring for the diesel. but with the somewhat questionable longevity of these new diesels coupled with much higher diesel fuel prices, not to mention the amount of gas you can buy for the initial $6000+ for the diesel motor, gas looks pretty good to me for what you will use it for..
Old Mar 28, 2008 | 05:31 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
I meant a "used" diesel. Obviously a new one would be much pricier, don't know if they are willing to deal on the new ones but you could get a nice 6.0 up to mid-$20's.
Old Mar 28, 2008 | 06:22 PM
Izzy351's Avatar
Izzy351
Go find you a nice, low mileage (under 100k) 7.3 -- you'll be very happy with it. Go look at the "Which Diesel" poll and see which diesel people seem to like the most...
I bought mine for 21k with 60k on it. I have 5x the truck I had with my Ranger, and get the exact same mileage. (17-19). When I'm not too nice with the skinny pedal, I get between 15-16. You gotta pay if you wanna play...
Redford tells everyone they don't need a diesel. "Need" is relative...
Old Mar 28, 2008 | 08:41 PM
rbaker6336's Avatar
rbaker6336
if your trailer is enclosed a diesel will get you about 3 mpg better,don't matter if trailer is loaded or empty
Old Mar 28, 2008 | 09:20 PM
Budman1962's Avatar
Budman1962
V 10 is the way to go. They only get about 1 mile per gallon less than the 5.4 and they have alot more power. The milage is actually better than the 5.4 when towing because it doesn't have to work as hard. And no smell and noise of a diesel. Diesel is $4.09 here.
Budman
