Clutch Adjustment
Old Dec 7, 2011 | 07:21 PM
cornking's Avatar
cornking
Clutch Adjustment
I have a zf-5. Can my clutch be manually adjusted or is it self adjusting? If manual than how do I adjust it?
Old Dec 7, 2011 | 07:33 PM
bashby's Avatar
bashby
It's hydralic, so its self adjusting. The linkage under the dash wears/ breaks and you'll get some slop there and a lower clutch engagement. Above the "gas" pedal is a small plastic bushing where the pedal assy hooks to the master cylinder. The shaft that the brake and clutch pedal pivot on (about 3/4" diamater) has some plastic bushings on the ends that wear out and will wear into the steel or aluminium bracket if you let them go too long.
Old Dec 7, 2011 | 07:43 PM
cornking's Avatar
cornking
OK, thanks Bashby
F-406
Aug 30, 2010 06:42 PM
JTyler11688
Jun 18, 2010 10:04 AM
97 HD
Jul 12, 2007 05:06 PM
84f250460
Jan 12, 2007 01:44 AM
sidecar marty01
Jan 9, 2003 07:54 PM
