no boost
Old Mar 27, 2008 | 12:46 AM
bri74's Avatar
bri74
no boost
got a 05 f-350 100k mi. 6.0 li. has less than ten lbs boost and can hear the air sounds like its being blocked like a exh. brake is on..
Old Mar 27, 2008 | 02:36 AM
bismic's Avatar
bismic
Are there any DTC's (codes) thrown ... like Code P0299 or P2263
Also - probably not applicable but fyi ....
6.0 Enhanced PCM Calibrations:
Some 6.0 F-Series and Excursions may exhibit a low power, low boost condition which clears when cycling the key off and restarting. This may occur while driving or after start-up. Other symptoms may include false cooling fan code P0528, and/or no or slow throttle response when engaging the TorqShift automatic transmission in gear. These symptoms may or may not become apparant after having the recall 03B06 performed prior to the end of May. The enhanced calibrations are available only with WDS versions 24.11 or later. Trucks that have had 03B06 done will only have PCM and TCM updates. Those which have not had the recall done will get PCM, FICM and TCM updates.
Broadcast Message 0356/SSM #16839.
Old Mar 27, 2008 | 04:46 AM
bri74's Avatar
bri74
ya we have a snap on solus pro scanner and it gave me a 2262 "boost not detected" also put in a new IPC due to no hot start
Old Mar 27, 2008 | 06:23 AM
bismic's Avatar
bismic
DTC 2262 - suggests
  1. Look for leaks: MAP hose, CAC (Charge Air Cooler) system, Intake, or Exhaust leaks.
  2. Also look for exhaust restrictions
  3. Lastly, may also be sensor related: MAP sensor or EP sensor
Old Mar 27, 2008 | 12:19 PM
Sarge261's Avatar
Sarge261
Had the same problem with my truck. Took it to the dealer and they found that the crossover pipes were plugged solid with soot. They replaced the pipe, MAP sensor tubes, cleaned the turbo and reflashed the ECU, TCM, & FICM.
Sarge
Old Mar 27, 2008 | 12:22 PM
MeyerzF350's Avatar
MeyerzF350
Hope you rounded up to 100K so you can get it fixed at the dealer for $100.
stephen3776
6.4L Power Stroke Diesel
26
Jun 6, 2024 11:25 AM
lakewood
13
Jan 17, 2020 04:14 PM
dieselman86
Oct 18, 2014 09:35 PM
Rishsd
Apr 26, 2013 09:07 AM
264WSM
Jan 28, 2012 02:06 PM
