Sponsored by: Auxito
Lowering...
Old Mar 26, 2008 | 10:37 PM
John_1953's Avatar
John_1953
Lowering...
I've come into possession of the 2001 Super Crew noted in my signature. I'm not a big fan of the fact that the thing is lifted at least 4". Granted, it looks cool, but my looking cool days are behind me. What would be involved in lowering it back to stock? I know I couldn't keep the 35" BFGs , but I'm thinking that all I need to do is remove stuff. Would this be a big deal? I've never dealt with lifted vehicles before and don't know where to start.
Old Mar 27, 2008 | 05:11 PM
LxMan1's Avatar
LxMan1
Well, your sig says supercab and your post says supercrew?? I'm confused
Anyway, if it hasn't had a body lift, then It is probably got different front springs and spacer blocks in the rear to raise it up.
Old Mar 27, 2008 | 05:34 PM
John_1953's Avatar
John_1953
Ooops, Ok fixed the signature. So, if I wanted to lower it I'd probably need: New springs for the front, probably shocks, tires and wheels and take out whatever blocks might be in there. Here is the only picture I have of it at this point.
Old Mar 27, 2008 | 09:13 PM
Bobby82490's Avatar
Bobby82490
Well it doesnt look like it has a body lift, so maybe(hopefully) the previous owner just put in spacers in the front and bigger blocks in the rear.. but if not you might need to replace the springs. If you found a f-150 at the scrap yard that wasnt hit on the axles, wheels, etc you could take the springs off of it..
Old Apr 3, 2008 | 02:20 PM
John_1953's Avatar
John_1953
Well, after checking it out a bit more, it does not seem like it will be too big of a deal. On the rear The only thing I can see is blocks on top of the axle. There might be an additional leaf spring, but they all look the same (age wise). There are 4 leafs, is that standard? Whats a good place to get the U-Bolts?
On the front, everything looks identical to the picture in Chiltons, seems that I would only need to find some springs. Seems odd to me that there isn't anything else under there. Basically all you need to lift a truck (at least a 4X2) is blocks for the rear and springs for the front (well, shocks too).
Old Apr 3, 2008 | 03:51 PM
2003f150xl's Avatar
2003f150xl
remove blocks from the rear, replace u bolts with stock ones from local parts store, replace front springs with stock ones. replace front and rear shocks with stock shocks. sell let overs on ebay. buy new tires
Old Apr 3, 2008 | 04:34 PM
John_1953's Avatar
John_1953
Thanks! Laid out exactly like I wanted Are there any spacers or anything between the springs and rear axle when stock?
Old Apr 3, 2008 | 06:43 PM
Bobby82490's Avatar
Bobby82490
On a 4wd they come with a small block, but 2wds dont have blocks on them.
JRSutton
Jun 29, 2013 02:18 PM
ufvj217
Jul 24, 2012 03:30 PM
79 Crewcab 4x4
16
Oct 20, 2009 12:18 AM
Flareside94
Apr 30, 2006 06:06 PM
proeliator
Offroad & 4x4
21
Sep 26, 2004 12:44 PM
