1994 5 150 fuel system issues
Old Mar 26, 2008 | 07:03 PM
jorson2's Avatar
jorson2
hoping for insite
5.8 efi engine 1994 with 215000
willstart and run fine cold after warming up will not start at all crank but no start
duel tanks rear tank switched on from dash will kill engine while front tank will not until truck cools off then will start and run fine until shut down then will not start
any suggestions would be so helpful thx
Doug
Old Mar 26, 2008 | 07:08 PM
Ultramagdan's Avatar
Ultramagdan
Hey Doug!
You will want to use our tech forums since this one is used for introductions. Click on the Forums tab at the upper left and scroll over the boards. Here's two solid links: https://www.ford-trucks.com/forums/forum28/ and: https://www.ford-trucks.com/forums/forum54/
Try those and see if the fine folks in them can get you going.
Old Mar 26, 2008 | 07:12 PM
jorson2's Avatar
jorson2
thx i will do
SeminoleSlim
New Member Introductions
Dec 25, 2007 02:39 PM
riptero
Aug 19, 2007 07:15 PM
piazzatim
Aug 12, 2007 12:54 PM
gampas twuck
Jul 7, 2007 12:20 PM
dwags15
Mar 18, 2007 05:48 PM
