dwags15 here, 2004 Excursion with 6.0L . Having a problem with the fuel pump. I changed the fuel filters and now it won't start. I am not hearing the electric fuel pump run when key is turned on initially. If I crack open the lid on the engine fuel filter no fuel comes out
Sorry to hear about your problem. You will need to post your question in our tech forums since this one is used for introductions and you won't reach the people you want here. Click on the Forums tab at the upper left and look over the list. There are a couple that deal with your engine and fuel system.
