pcm fuse blowing
Old Mar 25, 2008 | 10:09 PM
Bossco's Avatar
Bossco
Question pcm fuse blowing
I have been blowing the same fuse for a few weeks now. This is a work truck that I don't drive, so I don't know if it when they hit a bump or turn or what. I am thinking it could be in the steering column. Maybe they are adjusting the wheel height and it goes. You know employees....no help. It seems like it will go for days, even weeks without a problem. Then it will blow 2-3 times in the same day. Not sure of the number fuse, but it is the pcm. My accelerator and guages go out. Dealer has had it twice but can't find the problem. They replaced the whole fuse block because of a leaking windshield. 900 later it is still blowing the fuse. I know you guys can help. Thanks
Old Mar 25, 2008 | 10:18 PM
John311t's Avatar
John311t
D/C the fuel heater inside the fuel bowl. It could have burned out and keeps blowing the fuse.
Old Mar 25, 2008 | 10:22 PM
bfife's Avatar
bfife
still plays with trucks
A liitle more info would help. model,cab style.auto/manual. I know when I installed a console in my truck, I accidentally ran a screw through the wiring harness that runs across the floor of the cab. blew the fuse that powered the whole instrument cluster. check for any aftermarket installs. flashlight mounted to the floor etc.
Old Mar 25, 2008 | 10:30 PM
bdrummonds's Avatar
bdrummonds
Bossco, you may be on to something with the thinking of the chaffed steering column wire, but, next time it blows let us know what number fuse it is.
John is on to something with the fuelbowl heater shorting, but that will kill the truck, and wont let it restart. is your doing this?
Old Mar 25, 2008 | 10:33 PM
PaysonPSD's Avatar
PaysonPSD
Here's the back of the fuel bowl. Remove fuel heater connection. If fuse holds then the fuel heater has shorted out.
Old Mar 26, 2008 | 05:05 AM
Bossco's Avatar
Bossco
First off.....thank you for responding so fast. Posted the question before bed last night, woke up this morning and already have answers. You guys are amazing. Okay. Tried the fuel bowl plug. The fuse still blew. The truck is not dying, I just lose the accelerator and all the guages. It is a 20 amp fuse, again, I don't know the fuse number. There has been no alterations done as of lately. This just started happening out of the blue. The truck is a 99 F450 reg cab with buckets and a center console. Dump bed. 4 wheel drive auto....diesel. I think thats it. I can't believe I didn't put that in the original post. Maybe I should have the dealer try adjusting the wheel tilt and see if it blows. They have isolated everything on that circuit and found nothing wrong....maybe moving the steering wheel will cause it again. Keep the ideas coming......and thank you.
Old Mar 28, 2008 | 10:59 AM
PaysonPSD's Avatar
PaysonPSD
Let me give this a bump.
Old Mar 28, 2008 | 12:34 PM
maadman's Avatar
maadman
If you are also losing the accelerator and the truck will only idle then it is the fourth fuse from the right on the bottom row of the fuse panel. Change your OD switch in the shifter with a new one and you will probably solve your problem. Your workers are either using the OD button as an additional gear or or just bumping it by accident while driving. Hope this helps.
ismael
1997 - 2003 F150
Jul 12, 2009 06:11 PM
timberwoof
1997 - 2003 F150
Mar 9, 2009 08:24 PM
mcjones44us
17
Sep 14, 2007 02:12 PM
Gabel
1997 - 2003 F150
Sep 27, 2005 05:48 PM
cberster
Electrical Systems/Wiring
Jan 27, 2004 08:27 PM
