idle mixture setting.
Old Mar 25, 2008 | 09:46 PM
crescentwrencher's Avatar
crescentwrencher
ok, so im trying to set up a new carburetor(new for my truck)
when setting the idle mix. you use a vacuum gauge, right. so which vac. port do i tap into? a
also i have a few open vaccuum ports, should these be plugged up?
Old Mar 25, 2008 | 09:54 PM
Mil1ion's Avatar
Mil1ion
what engine.
ALL vacuum ports should be secured from leaks before any adjustments be done
Old Mar 26, 2008 | 01:03 AM
crescentwrencher
its a 390, now after i look at it there was only one. since my egr is no longer operational should plug its vacuum port/s?
Old Mar 26, 2008 | 12:57 PM
crescentwrencher
which vacuum port should i tap into?
Old Mar 26, 2008 | 01:22 PM
Mil1ion's Avatar
Mil1ion
The one just in front of the Carb.
Old Mar 26, 2008 | 01:41 PM
crescentwrencher
are you talkin bout the one my trans runs off of?
Thunderjet4x4's Avatar
Thunderjet4x4
Yes, all vac. plugs should be plugged into something or capped off. You will want to find direct manifold vacuum-probably off the vac. tree at the back of the intake manifold. When I set mine, I check idle speed, timing, and vacuum. Go for the highest vacuum setting, while keeping your idle and timing in spec., engine operating temperature. You will find a "sweet" spot where it sounds good and have good vacuum and throttle response, your idle and timing should be close and not vary much by then. Next, you should set your idle mixture screws, say 1/8 turn rich. I do this because, if you set it for max. vacuum and leave it, it probably will be too lean. It takes a bit of monkeying around getting it all right, yet I've set multiple engines up this way, and it works good-for me at least! I've seen bad mechanics set carbs up by ear, then wonder why the brand new engine has glowing exhaust manifolds, then soon followed by burnt exhaust valves. Search around, theres alot of info out there!
Happy Tuning!
Old Mar 27, 2008 | 11:38 PM
79Supercab400's Avatar
79Supercab400
anyone have any magic for a Edlebrock 650 carb tuning with the performer manifold? Seems really rich. Just installed a new HEI dist also.
Old Mar 27, 2008 | 11:49 PM
crescentwrencher
well i just did it, its pretty straight forward. make sure you have all your vaccuum lines plugged into something, then tap into a vac. richen your mix until you achieve the highest vac rating possible, then back off until pressure lowers then return to the highest pressure you got. then richen you mix just a tad bit.
im not sure how you control your mix on a edelbrock, im a holley guy by force.
here you go this should help,
http://edelbrock.com/automotive_new/...ll/index.shtml
Old Mar 27, 2008 | 11:50 PM
crescentwrencher
make sure you use a vac. port on the manifold!!!!!!!!!!!
Old Mar 28, 2008 | 12:50 AM
OldMetal's Avatar
OldMetal
Keep in mind these are idle adjustment screws only and have no effect on fuel mileage or preformance.
Old Mar 28, 2008 | 01:02 AM
78f-150Supercab's Avatar
78f-150Supercab
They run rich out of the box. Get the metering rod and jet kit. I had to go two stages leaner with mine. Make sure to clean the deposits off your spark plugs if it's been running rich.
