Is it safe to replace 1 rotor
Old Mar 25, 2008 | 09:34 PM
870's Avatar
870
I know when replacing pads or shoes to replace in pairs. Is it safe to replace just 1 rotor? I just got this 89 F-150 4x4 & was going through the front end. I found one of the inner bearings races was loose. Put in a new race & it's loose. I figured at one time the bearing got hot & locked up & spun the race.
I can get rotor & hub for 75.00 from Bronco Graveyard. Hubs alone everywhere else start at 60.00. Just want to make sure that it's ok to just replace one rotor.
Old Mar 25, 2008 | 09:48 PM
quicklook2's Avatar
quicklook2
the general rule on brakes is to do the same thing to both sides at once.
Old Mar 25, 2008 | 09:53 PM
frederic's Avatar
frederic
Generally you want to replace brakes on both sides, just as you would tires to keep things symetrical in wear and gripping ability.
In a pinch I've broken this "rule" but addressed it within a week or two for this reason.
Rotors aren't terribly expensive.. how much is your life/family/cargo worth? That's the way I look at it.
Old Mar 25, 2008 | 10:00 PM
brown 4x4's Avatar
brown 4x4
The hub and rotor are separate, held together by the wheel studs. You could switch your old rotor to the new hub if you wanted.
Old Mar 25, 2008 | 10:03 PM
99whiteford's Avatar
99whiteford
you now have two used rotors on the vehicle.I would think replacing only the bad rotor would be okay.If i were replacing brake pads I would do both sides.
Old Mar 25, 2008 | 10:52 PM
whdahel's Avatar
whdahel
Its not the "best thing to do" but it should work out fine....... I had a caliper hang up only like 15k after a brake job so I ended up replacing caliper/rotor and pads on one side. yes, one side. Not a lick of problems! I have seen others do it with no problems . Also I have seen people put pads on worn rotors with no problems. However I am sure the braking distance wasnt as short with the new pads. It can and has been done.
Old Mar 26, 2008 | 06:12 AM
pacrewchief's Avatar
pacrewchief
Is it safe......yes is it advisable NO for all of the above reasons.
Old Mar 26, 2008 | 09:10 AM
dave2's Avatar
dave2
Rock auto has a hub for 50 bucks. What if you'd replace the hub and keep the brake parts even? Or is there more to it than that?
Dave
Old Mar 26, 2008 | 09:15 AM
vasten's Avatar
vasten
If the problem is with the hub/bearing why replace the rotor? If there is nothing wrong with the rotor that is on there now then pop it off the bearing, which you should have to do to get the old one off, and replace it on the new bearing. And save yourself the added cost of the rotor and the concern of weather or not it is safe.
