Leaf spring issue - READ PLEASE ??FORD - Fault?
I agree that the 1/2" difference in the back is negligible. The shackles could each be flexed to one side or the other 1/4" which is nothing on a leaf spring suspension.
Ford may also be widening the frame as it goes forward to accomodate radiators, engines etc. Because of ride height and suspension movement the the front of the frame needs to be wider to make room, since it is also higher for mounting the springs. Obviously it is just outside the limitation for the setup as the front springs are nearly flat from the factory. As it goes towards the back those limitations don't exist. The location of the body mounts and the rear spring mounts are outside of the frame rails, thus the frame needs to be narrower.
Just like the turning radius. They could place the leaf springs closer together but that would mean the engine would have to go up higher to make room. It's a compromise. A side effect of the widened frame in the front may be the stability as mentioned, but I don't think that was the primary intention since the trac bar is a much better method of locating the front axle.
A big part of solving a problem like this is accurate, repeatable measurements. Are the trucks all off by the same amount? How much of the difference is due to measurement errors, and how much is actual? How much is due to manufacturing tolerances? How much is due to your aftermarket lift? How can you compare a stock truck to a lifted truck, if you don't have accurate repeatable measurements?
A laser level is only as accurate as the factory schmoe that calibrated it, whereas a plumb bob is pretty foolproof, that was my point. If you don't agree, or don't care, that's fine, but don't get all indignant at the mere suggestion that you refine your measurement techniques.
Good luck with your problem.
I am sorry if there is a slight hint of "attitude" But do the actual numbers matter? If it is over 3" it seems pretty severe to me, do you want plumb bob measurements - would it make you happy? Or help others help me with my problem, then i will get them for you, If you gave me a valid reason why you need EXACT measurements and cannot trust a laser level (which may have been used to build the very house you live in) then I will do the plumb bob...
Its just that i am busting my butt trying to get as much info as possible. A hand level was no good, now a laser level is no good. Tonight (given the wind is not extreme) i will try to get measurements with a plum bob - hope i can find it.
kenny
THANK YOU for that post... so i am not crazy its just very depressing to pinpoint issues like this
thanks, kenny
I have new springs to go in that may solve the clunking i have (we think its the springs since i replaced everything else), but its a strange problem and want to learn about it
kenny
THANK YOU VERY MUCH
http://www.afcoracing.com/tech_pages/leaf.shtml
it explains alot
kenny
what springs do you have and have you put 700 ft lbs on your track bar bolts... thats what I had to put on mine along with some friction tape to prevent it from acting up
kenny
You mentioned yourself that Superlift stated that they had an issue and complaints with the bushings you currently run.
Like I posted before, if they weren't aimed at each other it would be hard to get the leaf springs in and more importantly the spring eye bolts to go through.
Having the springs Cocked did not seem to make sense to me at first but it is finnally starting to. Cocked springs will still have extra stresses in the sideways motion then having the springs mounted || BUT like you have been saying all along, with a quality bushing I wont notice.... once i get the new springs in there i will prolly be fine. But i may have to get new springs mounts, since these appear to be opened too wide.
I have never had those bolts out myself personally, so i do not know how hard it was for the guy who changed my springs to do that. I got upset with him cause of not torqing everything down right when he did it so theres no sense in me calling there right now. Everthing is torqued properly now according to my gearwrench torque wrench. And my pittsburg big torque wrench.
My next step is to have somebody who does this all the time look at the springs, the spring mounts and let me know if i need new mounts. I would not mind buying new mounts to go along with new springs (that i have ready to go in) - Actually this is what i prefer to do if the mounts are questionable at all.
As for the bolt for the spring eye - the bushing i have (the one i showed you a pic of) has a metal sleeve on the inside, if the bolt does not take up most of the space of this sleeve there will be play in it too wont there? Well maybe not since when the weight of the truck is on the spring it will be pulled to one side.
I will check tonight the extra bushing i have inner hole DIAM to the new spring inner hole DIAM.
trust me - i want it to be right, i do not remember my stock springs doing the noise, I have to beleive the clunk is coming from this issue, the new springs will prolly fix it. I just wanted to know why the offset - that other post with the link to the other website really helped explain why. IT has to do with handling and such - now it makes sense.
Kenny
