v6 or v8?
Old Mar 27, 2008 | 03:24 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Originally Posted by Big Bad
More economical engine + lighter curb weight = better gas mileage every time
the 4.6 weighs in at nearly the same as a 5.4
the 04+ F-150 has 600# to 1000# more per model than the previous generation F-150s
Old Mar 27, 2008 | 03:32 PM
Big Bad's Avatar
Big Bad
Re-read my post and rethink your response. My response was geared towards the 01 4.6 vs. the 06 5.4, my 01 S'crew weighs a good 700 lbs. less than my buddies '06 S'Crew.
Regardless of the generational weight differences, a bare 5.4 NVH block weighs 210 lbs. vs. 159 lbs. for a bare 4.6 iron block. Throw in the 5.4s heavier crank, rods, intake manifold and timing chain cover and you're looking at nearly a 100 lb. weight difference between the two engines once assembled and dressed. Then there's the 8.8 vs the 9.75.
Old Mar 28, 2008 | 12:05 PM
high roller ford's Avatar
high roller ford
Smile V6 Or V8
thanks I guess v8 will do in my case, by the way I am going to look for 2 wd trucks thanks dwight
Old Mar 29, 2008 | 04:07 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
oh...I misread your post. We're saying the same thing but from different sides.
640 CI Aluminum FORD
General Automotive Discussion
Jul 6, 2024 01:53 PM
Chief Many Inches
Nov 4, 2016 08:46 PM
rew729
New Member Introductions
Mar 18, 2015 01:23 PM
66 BADBOY
Mar 22, 2013 08:16 AM
