v6 or v8?
Old Mar 25, 2008 | 05:38 PM
high roller ford's Avatar
high roller ford
v6 or v8?
hi I am looking for 04 0r up to 06 reg cab sb f150 just starting to look. I think I know what I want but have not test drove anything yet just started watching the paper etc I know I want auto trans but what about v6 or v8 ? I have always had a v8 in a truck but would I be happy with a v6? I don't tow and would be used for small things but don't know if i would be happy does the v6 wine alot? what v8 in these year trucks is the best? anything i should look out for in these year trucks? thanks dwight
Old Mar 25, 2008 | 05:47 PM
Tom's Avatar
Tom
I'd suggest looking at the 4.6L V8. It's the smaller of the two available V8s, and should suffice just fine for most regular driving.
The 5.4L is the biggest V8 they put in these trucks, and is a great motor, but is really only needed when you expect to tow.
Either way, don't expect it to drive like a mustang like so many on this board!
Old Mar 26, 2008 | 01:58 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
that is so true...especially those guys who complain about the trucks "lack of performance" and have nothing to compare it to except the new Tundra. I've got me a go fast car (in sig) and the truck is for style and functionality
what are you going to use the truck for? a daily driver? work? mix of everything?
the V-6 is sorta bearable with a stick, but the auto is...not fun. the V-6 is actually getting phased out in 2009 since it has been determined un-needed as the 4.6 gets about the same MPG and has better HP/TQ #'s
the 4.6 is underpowered, and only gets about 1-2 mpg more than the 5.4. You WILL notice the difference between them.
the 5.4 is adequate power wise. but it isn't a tire melting screamer. just gobs of torque and a great "all around, good for everything" motor. actually, that describes all the F-150's, but more so when equipped with the 5.4
Old Mar 26, 2008 | 05:38 AM
high roller ford
Thumbs up V6 Or V8
thanks guys that what I was thinking that the v6 is going to cry with a auto trans I think the v8 is the way to go then .is there a year I should watch out for or somthing I should look for? thanks
Old Mar 26, 2008 | 12:45 PM
osbornk's Avatar
osbornk
Buy the best truck at the best price you find. They all get about the same MPG but the differences in power is great. The 4.6 V8 has the longest track record and is dead reliable. My cousin has an 05 with 209,000 miles on it and it still has the original plugs. I get slightly more MPG on the interstate with my 5.4.
Old Mar 26, 2008 | 02:25 PM
Dustin1690's Avatar
Dustin1690
Well i would go for the V8 cause im a V8 kind of guy the 4.6l is about almost the same on gas as the v6 in some cases but more power and torque for daily driving
Old Mar 26, 2008 | 07:26 PM
tjthegreat's Avatar
tjthegreat
go with the 5.4 the 4.6 was a worthy repalcement for the 302,as was the 5.4 for the 351,dont even bother w a 4.2,junk compared to its predecessor.buddy of mine ghas a 4.2 which only gets around 16,4.6 and 5.4 are pretty colse on gas mileage so id just go with the 5.4
Old Mar 26, 2008 | 08:12 PM
F0rdzTuff's Avatar
F0rdzTuff
Wink
If you don't care about the spark plug issues, or the cam phasers, then any of them will work fine. The 08's don't have those 2 problems....supposedly. I know my plugs are different, and my heads. Wouldn't know about the cam phasers yet.
I'm sure the 09's will have their own quirks.
Old Mar 26, 2008 | 08:30 PM
gui88ford's Avatar
gui88ford
get the 5.4L
i owned a 4.6L and i get the same if not better MPG with my 07 with the 5.4 vs. my 01 i had with the 4.6L....
i got 14.5 around town with my 4.6L and i've gotten consistently 16.5 with my 07 5.4L on the same trip daily....
5.4L
Old Mar 26, 2008 | 09:47 PM
boots6868's Avatar
boots6868
I have had my spark plug trouble wont even get in to it one more time. You will be tickled with the 5.4 any year!! It is a little monster. cruising gets you acceptable gas milage and towing you get awesome power. I tow a 6000 lb camper empty and on the highway from ohio to pa I got 12 mpg with the cruise control on at 65 mph. not too bad
Old Mar 27, 2008 | 04:44 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
the 04/05 models had some growing pains
if you can spend the money, get a 06+. the problems have pretty much been ironed out by then. although, you can probably pick up a very nice 04/05 with 0 issues for pretty cheap...see if the dealer will give you an OASIS report for any truck you buy. the OASIS report is a Ford internal system that tracks repairs for each vehicle a dealership has seen
Old Mar 27, 2008 | 08:25 AM
Keystone.45's Avatar
Keystone.45
I just finished truck shopping myself and one thing you didn't mention is if you're looking for 4 wheel drive. Sounds like most people are recommending the 5.4, but I don't believe Ford will put a 5.4 in a standard cab 4x2. Just something to keep in mind.
Old Mar 27, 2008 | 01:57 PM
Dustin1690's Avatar
Dustin1690
I think keystone is right but you never know i think you can get the 5.4l in 2wd just not standard cabs
Old Mar 27, 2008 | 02:42 PM
tjthegreat's Avatar
tjthegreat
my brother has a 4x2 5.4 its with a supercab tho
Old Mar 27, 2008 | 02:56 PM
Big Bad's Avatar
Big Bad
Originally Posted by gui88ford
get the 5.4L
5.4L
Huh? I have an '01 S'Crew 2wd 4.6L and average ~18.5 mpg in mixed driving, a friend of mine has an '06 S'Crew 2wd 5.4 and averages 16mpg.
I followed him on a road trip, travelling the same speed and edged him by almost 3 mpg.
More economical engine + lighter curb weight + identical gearing = better gas mileage every time
