I'm asking a serious question here because I really don't know. Does the 3" PVC slide inside of the neck of the 6637? And if so, I would guess the walls on the PVC are probably at least 1/8' thick. So does that reduce your flow or not? The factory tube slides right over the neck of the 6637, so if you're sticking a piece of plastic plumbing inside of the neck you are reducing the flow for the entire system. It would be like putting a piece of 3" pipe in your 4" turbo back exhaust and calling it a 4" turbo back, when in reality that little piece of 3" turns the entire exhaust into a 3" exhaust.
You are right, it will decrease flow some. How much, I have no idea. the 3" coupler is actually 3.5" inside (1/4" wall thickness on the pipe, a 3" pipe means 3" hole size) which is why a 3" coupler is 4" outside diameter.
I keep having a hard time with the 3" plastic. Why do so many folks find this a necessary step? My stock tube slid right onto the 6637 with very little effort, on my part anyway. ZX250 did most of it while I engaged in one of the other steps in the instructions. But with each filter change since, it has been very easy to put right on.
Mark,
Same here. I used some brake cleaner on a rag and wiped off the rubber of the intake hose and the flange of the 6637. I had to stretch the hose a little but it slid right on. I tightened up the stock clamp and it's been working great ever since. I think the folks with the early 99's have to use a 45 degree elbow, but I didn't see the need to do anything but remove the upper part of the air box. I tie wrapped the intake are sensor near the filter and didn't bother remounting the filter minder since I've found that they're not trustworthy.
No kidding! Are we related? I've been told I can trace my roots back to Daniel Boone, but have never bothered. Thanks for the support. I do believe everyone but those with the early 99 are simply guilty of taking the easy way out.
I resemble that remark.
Actually I got scared off by a few stories about some of the filters popping off the factory tube so I chased down some exhaust pipe. I drive too many miles in a day for a filter to come off.
The pipe ensures that it cannot pop off of there.....the factory intake hose mounted directly to the 6637 is plastic against plastic/rubber. With the amount of air flow, there is no way I wanted to chance it blowing off of there, and allowing dust/dirt/mud directly into the turbo intake! I think it's a great insurance step.....
I thought I saw posts here saying that they has trouble with their filter coming off which sent me out to the garage to find something to ensure this did not happen. I had a 3" plastic PVC coupler and like stated above inside diameter is 3.5" with the side wall measuring 1/4" for an overall diameter of 4". The actual decrease in diameter to the air inlet is 1/2" over stock. I feel 1/2" of less air flow is OK for the peace of mind to know that the filter will not come off. When I first installed my 6637 I noticed that the filter inlet side wall is not that thick and when you put the inlet tube over this I was worried that by tightening the hose clamp that the filter might compress eventally. I just feel that 1/2" of air flow is worth the peace of mind that I know there is no chance of these connections coming apart. Still way better air flow than my stock box.
After my last post I thought I should clarify before I offend someone. I totally agree when it comes to air flow, bigger is better. In my case though, when I read posts about filters coming off the only thing I could find in my garage was the PVC connector. I am sure I will find thin wall 4" pipe to replace my PVC connector eventually.
Ok, I give, who is selling a "Cold Air Box" for the 46637?
Thanks,
Richard
Originally Posted by sflem849
NAPA 6637 filter
4"od x 4 long pipe
4" constant velocity clamp
You win. I am sure you could figure out the proper order from that, but there is a link in my sig that will show you how to do it, IIRC. It is simple! If you want to get a little more complicated there is a cold air box option that just came out last week. That would be a pretty sweet little improvement.
Howdy all
I do a fair bit of 4wd'n and tend to go swimming every now and then with my f truck.
Is this filter a viable option for me ?
If not what would be a descent intake set up for me
If it wasn't mentioned, ziptie your air temp sensor to something like the brake master cylinder tubes. I also zipped the airfilter sensor up there too, because its useless.
is anyone running the 6637 piping from riffraff, i sent him an email yesterday and recieved a response back with pics, i am thinking of ordering it but wanted to see if anyone has some input on it, looks like clean setup.
