Ranger Package code?
Old Mar 24, 2008 | 07:50 PM
Customcab's Avatar
Customcab
What was the special identifier on the body code for a Ranger package 65 or 66 model? Also how is a Camper Special label as well??
Mitch
Old Mar 24, 2008 | 08:24 PM
garbz2's Avatar
garbz2
No known method is on the warranty tag info.
Only way is the original badging saying ranger or CS.
Garbz
Old Mar 24, 2008 | 09:23 PM
camperspecial65's Avatar
camperspecial65
I second that...Ranger has the buckets but those are easily gotten too...as for the CS pkg...its essentially beefed up suspension and basic mechanics..
- cs65
Old Mar 25, 2008 | 05:32 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by camperspecial65
I second that...Ranger has the buckets but those are easily gotten too...as for the CS pkg...its essentially beefed up suspension and basic mechanics..- cs65
Is it a true Ranger?
The holes in the floor pan for the bucket seats brackets and console will be factory punched out. The holes in the rear of the cab for the gas tank "drape" will be, too.
Just try duplicating those nice clean factory punched out holes with a drill.
First Camper Special: 1965 F100.
There were no 1965 F250 Camper Specials.
1966 was the first year for F250 Camper Specials.
The Camper Special package includes: Dual Western Mirrors, 70 amp hour Battery (R-27-F), Extended Tailpipe, Amp and Oil Pressure Gauges, H/D "Rapid Cooling" Radiator, H/D Springs and Shocks, Camper Wiring Harness, Unique Fender Badges, 55 Amp Alternator, 300 I-6 or 352 engines, COM or 4 Speed Transmissions.
Old Mar 25, 2008 | 05:47 AM
leonharu's Avatar
leonharu
On a Ranger you may check the trim code and come up with an answer if truck is real or not.I have seen several Rangers and they all were automatics.Correct me if I am wrong,but has anyone seen a Ranger with three on the tree?I removed a Ranger package out of a Camper Special several years ago.I have pictures of this truck I found in salvage yard.
Old Mar 25, 2008 | 06:16 AM
NumberDummy
Why didn't I think of that?
The Rangers bucket seats were all vinyl.
No woven plastic anywhere.
btw: There's no trim code on the Warranty Plate.
The first digit of the Body Code determines the interior color.
Ranger Body Codes. The parts catalog specifies "bucket seats."
1965 Ranger
F = Red Crinkle all Vinyl
G = Black all Vinyl
H = Palomino all Vinyl
1966 Ranger
T = Black Crinkle Vinyl & Black Rosette Pattern Vinyl
U = Parchment Crinkle Vinyl & Parchment Rosette Pattern Vinyl
V = Red Crinkle Vinyl & Red Rosette Pattern Vinyl
These are the only colors listed for 1965/66.
Old Mar 25, 2008 | 06:54 AM
leonharu's Avatar
leonharu
Thanks Bill.You certainly are a great value to this site.I wish there was some way to check and see exactly how many Rangers were produced.
Old Mar 25, 2008 | 03:08 PM
camperspecial65
there were indeed 65 CS made...2 fender badges made...Sec 166, pg 7, 3/4 way dn pg...
65 F250 before 600,001 ' Ford Camper Special' C5TZ 16720 A
65 F250 from 600,001 ' Ford 250- Camper Special' C5TZ 16720 H
As for the F100's, I stand behind Bill on that one...no ID number mentioned like on the 3/4 tons.
- cs65
Old Mar 25, 2008 | 06:54 PM
Customcab's Avatar
Customcab
Thanks guys; so I see its hardto determine those two type; I will view the flooring on any Ranger I see at Supernationals. I guess its easy for someone to clone aRanger; I also thought all CamperSpecials where 250's didn't know the initial ones where not. I always knew there was a list of package accessories for camperspecials. Will one day own one of each.
Mitch
lonewolfone
Aug 11, 2013 01:15 PM
Gary Lewis
Dec 28, 2011 12:02 PM
Boss9F100
45
Jul 13, 2010 12:03 PM
JBradley500
22
Dec 15, 2006 01:43 AM
ranger429
24
Aug 9, 2004 12:49 PM
