Rough Idle
Old Mar 24, 2008 | 06:13 AM
convincor's Avatar
convincor
Rough Idle
Cold starts seem to be real rough. Engine lopes like a huge cam gasser.
Seems like it's only firing on a couples cylinders, then clears up and runs fine.
Glow plugs again?? Just did them last year for first time in 230,000 miles so i'm thinking maybe something else?
Old Mar 24, 2008 | 05:23 PM
Action4478's Avatar
Action4478
If it's an auto ,, try starting it in neutral ...
May want to test the GPR again ,,,they don't last long ...
What weight oil are you running ?...
Old Mar 24, 2008 | 06:38 PM
convincor's Avatar
convincor
15w/40 Rotella. Been running it for 5 years. Change every 5000.
Was reading some today and sounds like bad injectors.
How are they tested?
Trans in Neutral? why?
Old Mar 24, 2008 | 07:45 PM
medhvac's Avatar
medhvac
will u can remove all injectors and have them bench tested!our u can remove your valve covers and start ur engine,while the covers are off!and unplug your injectors one at a time till u unplug the one that makes ur truck run better than u found it!
Old Mar 24, 2008 | 07:48 PM
Action4478's Avatar
Action4478
Trans range sensor can cause the romps , occasionally...
Old Mar 24, 2008 | 07:51 PM
Action4478's Avatar
Action4478
Also , the LPOP can cause the problem ,, not supplying enough oil at startup ....lighter oil helps ....maybe even synthetic.....
Old Mar 24, 2008 | 08:42 PM
convincor's Avatar
convincor
It'll only run that way for 5-10 seconds, then smooths right out like normal.
Did the cps about a year ago so not in any hurry to go in for the recall.
But may do it soon and just have a scan done while I'm there and see what comes up.
Old Mar 24, 2008 | 08:46 PM
medhvac's Avatar
medhvac
i was trying too answer your injector question ! watch out for that new CPS!
Old Mar 24, 2008 | 08:52 PM
convincor's Avatar
convincor
i relize that. what I'm saying is by the time i'd start it to the time I got up there It would be running fine.
What's with the new CPS?
