buying first diesel
Old Mar 23, 2008 | 11:01 PM
twwtruck's Avatar
twwtruck
Question buying first diesel
im looking at a 1990 f-250 7.3L 4x4 is there anything i should look out for. and is this a good year. thanks
Old Mar 23, 2008 | 11:31 PM
David85's Avatar
David85
Its not a bad year, but in general the late 1985-1987 are the best for absolute reliability at all cost. The advantage of the trucks after 1988 is the overdrive transmissions. Not as strong, but better for the real world where MPG is a concern.
1990 will be a 7.3L IDI unless it was a swap. Not a bad engine, but the 7.3 is more prone to cavitation of the cylinder walls than the older 6.9. Try to find out as much of the service history of the engine as possible and in particular, if the coolant PH was properly maintained (prevents cavitation).
The transmission will either be a ZF 5 speed if it is a manual, or an E4OD if it is an automatic.
The ZF5 is a pretty good tranny, if it shifts well and feels nice and tight, that its probably good to go.
The E4OD is VERY failure prone in the early years. If this truck has more than 100 000 on the clock it is most likely a rebuild. If this is an OEM ford rebuild, that would be the best. If it was done by some one else, find out who. A rebuild for an E4OD usually runs at least $2000.
Pay close attention to how the E4OD behaves. Feel how quickly it engages in forward and especially reverse, delayed engagement is bad. Pay attention to how it shifts, make sure if is not too hard or soft (does not slip). Light throttle should be nice and easy, hard throttle should firm up and NOT slip during the shift (slip will be revealled by an increace in RPM during an upshift, than finally coming back down when synchronized to the next gear).
Use the overdrive cancel switch. The 1990 model year uses the OD cancel light to display any fault codes. Some folks might disable the light to hide any fault codes. If the transmission responds, thats good, if the light never comes on, or flashes repeatedly, thats bad.
If you find any evidence of starter fluid being used on the engine, walk away (usually will crack the top compression ring, or other internal damage).
Old Mar 24, 2008 | 12:23 AM
twwtruck's Avatar
twwtruck
well its only got 76000 miles so i figure every thing should be pretty good
Old Mar 24, 2008 | 10:49 AM
tpolley's Avatar
tpolley
"1990 will be a 7.3L IDI unless it was a swap. Not a bad engine, but the 7.3 is more prone to cavitation of the cylinder walls than the older 6.9. Try to find out as much of the service history of the engine as possible and in particular, if the coolant PH was properly maintained (prevents cavitation)."
how do you test the ph level on the coolant?? is there a test strip i can get at oreilly's? is there some additive i need to add every so often?
Old Mar 24, 2008 | 11:24 AM
speedrdr's Avatar
speedrdr
NAPA sells stuff called NAPAKool cooling system treatment # on jug is 4058. htere's a coolant test strip kit NAPA part # 4107 that has test strips that check freeze point, nitrites and pH of coolant. it's cheapest insurance you can pay to make sure everything's hunky-dory in the coolant system. o'reiley's probably has something like that but we don't have one here, that's why i gave you the napa numbers. o'reiley's can probably cross reference them---mayby.
speedrdr
Old Mar 24, 2008 | 01:24 PM
David85's Avatar
David85
Make sure you check the expiry date on the bottle of testing strips, the guy who sold me my strips nearly sold me product that was 3 months expired. I pointed out the date and he seemd so supprised, yeah right. Just check the date to make sure the product is still sound, otherwise it is good to have.
Old Mar 24, 2008 | 04:13 PM
Dave Sponaugle's Avatar
Dave Sponaugle
76,000 on the speedo may mean 176,000 or 276,000 or even 376,000 just as easy as it means 76,000.
76,000 miles on an 18 year old truck would only be an average of 4222 miles a year or 81 miles a week.
It is possible, but I bet there is at least a 1 in front of the 76,000.
I don't drive very far any more, and I ran over 81 miles today.
Old Mar 24, 2008 | 08:29 PM
jasiebol's Avatar
jasiebol
i have a 1990 f-250 2wd auto 132000 miles, love it great truck tranny shifts great no broblems, starts great even on the coldest morning without being pluged in.
Old Mar 25, 2008 | 02:09 AM
twwtruck's Avatar
twwtruck
its really nice and the person is the origional owner
Old Mar 25, 2008 | 02:11 AM
twwtruck's Avatar
twwtruck
also what does IDI stand for
Old Mar 25, 2008 | 02:34 AM
David85's Avatar
David85
IDI = Indirect injection.
DI = Direct injection
IDI diesels have a prechamber above the piston where the fuel is injected before it reaches the cylinder. DI diesels inject the fuel directly into the cylinder and have no prechamber.
Old Mar 25, 2008 | 11:55 AM
twwtruck's Avatar
twwtruck
Ok Thanks For The Advice Fellas
Old Mar 25, 2008 | 01:01 PM
gasgrunt88's Avatar
gasgrunt88
My truck is a 90 f250. It's been a great truck. I think the tranny is starting to go though. Other than that, its a solid truck that will haul ***** to the wall. Lots of power, good n loud...my kinda truck.
Old Mar 26, 2008 | 12:11 AM
twwtruck's Avatar
twwtruck
what kind of exhaust are you running
Old Mar 26, 2008 | 12:33 AM
George D.'s Avatar
George D.
David85 what does it mean if the trans delays going in to first or revers? mines a bit sluggish what causes it?
