302 HO swap
Old Dec 2, 2002 | 08:31 AM
dunnit52's Avatar
dunnit52
302 HO swap
I know this has been talked about before but, what changes need to be made to put an EFI 302 (HO) out of a mustang in a '92 F-150. This truck has a roller block 302 in it. I am pretty sure it has a hole (at the very least) in the #7 piston. And, since I've become a mustang geek My mustang parts inventory is becoming pretty overwhelming.
The moral to the story is, I want to put a mustang HO in this truck. I figure the intake and electronics will need to be exchanged, anything else? Thanks....
Old Dec 2, 2002 | 09:52 AM
desperado_18_2000's Avatar
desperado_18_2000
302 HO swap
Since the 5.0HO engine uses a different firing order, you will have to either change cams, or change computers (im' guessing). but it will be something along the lines of these two. Also the intakes will have to be changed out. other than that it should be fairly easy.
Old Dec 2, 2002 | 10:20 AM
EPNCSU2006's Avatar
EPNCSU2006
302 HO swap
All you will have to change is the firing order - hook up the plug wires in the 351 firing order - the HO uses the 351w firing order, while the truck 302 uses the older 302 firing order. The trucks use speed density system and bank to bank injecting, so as long as you get the two sides of injectors hooked up correctly (and you haven't done a mass-air conversion), that shouldn't be a problem. That is assuming you use the truck computer, sensors and intake manifold.
Old Dec 2, 2002 | 12:10 PM
dunnit52's Avatar
dunnit52
302 HO swap
Not sure I understand the hooking up the injectors correctly. Wouldnt' the injector harness hook up the same as stock? Would I need to use the distributor from the truck in the HO Block? Thanks for the help.
Old Dec 2, 2002 | 02:36 PM
EPNCSU2006's Avatar
EPNCSU2006
302 HO swap
I think Ford went to a remote mount TFI in '92, so if that's the case, then I would use the distributor from the truck - just be sure to change the order of the plug wires on the distributor to the 351 firing order. And yes, just hook up the injectors like the stock truck motor and that shouldn't be a problem.
Old Dec 4, 2002 | 01:38 PM
dunnit52's Avatar
dunnit52
302 HO swap
One more question about the swap....Will the cam shafts need to be changed in this swap? Let me make sure I get this right.
Use the stock truck computer.
Use the truck firing order w/distributer
Cam shaft change?
Hook up the injectors same as stock truck application
Is the crank shaft the same in the truck vs. 302HO applications? Sorry for the redundant ??'s Don't like doing it twice
Old Dec 4, 2002 | 03:37 PM
EPNCSU2006's Avatar
EPNCSU2006
302 HO swap
The camshaft does not have to be changed if you change the firing order at the distributor. Either distributor should fit the engine, but if the one from the HO motor doesn't plug into the truck wiring harness, I would use the truck distributor, but make sure you hook up the plug wires in the 351(302 HO) firing order. The stock truck computer with the stock injectors hooked up like stock should work fine. I think the cranks are the same, the only difference being in the cam, necessitating the need for the change in firing orders. I hope this answers your questions.
Old Dec 4, 2002 | 04:28 PM
dunnit52's Avatar
dunnit52
302 HO swap
Thanks Buddy, sorry to be a PITA, I appreciate the help. Don
Old Dec 16, 2002 | 12:39 PM
f1504x450ho's Avatar
f1504x450ho
302 HO swap
i just swapped a mustang motor in my truck and explaned it 7 posts up
read f1505.0 to 5.0ho i think its 7 posts before this one
Old Dec 16, 2002 | 05:29 PM
moose4130's Avatar
moose4130
302 HO swap
smbikes
Mar 31, 2010 02:03 PM
blacklab1
Oct 9, 2009 10:08 PM
truckfarmingcanuck
Mar 1, 2009 12:10 PM
JPontius
May 10, 2005 07:52 PM
BrianLXcpe
Jul 10, 2002 04:37 PM
