Compression Test
Old Dec 13, 2002 | 12:16 PM
Border3899's Avatar
Border3899
Compression Test
Hey Everyone! Does anyone know an approximate cost of having a compression check done on a 302?
Old Dec 13, 2002 | 05:23 PM
mudder trucker's Avatar
mudder trucker
Compression Test
you could save some $ if you bought a tester yourself. its real easy. mudder trucker.
Old Dec 13, 2002 | 05:32 PM
Border3899's Avatar
Border3899
Compression Test
How do i go about doing a compression check if i purchase one?
Old Dec 13, 2002 | 05:45 PM
mudder trucker
Compression Test
just pull each spark plug one at a time, then you thread the tester into yhe plug hole, crank engine over, and see what pressure you have. mudder trucker.
Old Dec 13, 2002 | 05:54 PM
Border3899's Avatar
Border3899
Compression Test
Hey thanks, i'm new to all of this but i think that's the option i'm going to go with. appreciate the help!
Old Dec 13, 2002 | 06:15 PM
EPNCSU2006's Avatar
EPNCSU2006
Compression Test
If it's fuel injected, I'd disable the fuel pump(s) so you don't have fuel squirting in there. Crank the engine until the guage won't go any higher (usually 3-4 compression strokes).
Old Dec 13, 2002 | 09:41 PM
Mike W's Avatar
Mike W
Compression Test
Take out all the plugs and wire the carb throttle plate wide open. One type of gauge has a rubber plug that you hold in the plug hole. The other type threads in the plug hole and usually gives more accurate readings.
Old Dec 14, 2002 | 11:15 AM
Quantrex's Avatar
Quantrex
Compression Test
Old Dec 14, 2002 | 09:00 PM
jimandmandy's Avatar
jimandmandy
Post Compression Test
I use a remote starter switch and jumper to the small terminal on the solenoid to crank the engine. That way the fuel pump is off and you can do everything from under the hood.
Jim
Old Dec 15, 2002 | 07:24 PM
gamehunter's Avatar
gamehunter
Compression Test
As you can see, there are MANY methods of doing this, but the easiest way I have found is to simply disconnect the coil wires. This prevents ANY spark from possibly igniting the fuel. It is still a good idea to go one step farther and use a remote starter like stated above so you don't have to engage the ignition at all, but this seems to work fine for me. If you dont prevent fuel or spark while testing you could wind up with a serious engine fire and possibly worse. I know a guy who forgot to disconnect the coil and ended up acquiring major burns all over his body when the fuel ignited not to mention major underhood damage to the car. Not a smart idea. Play it safe and you will be fine.
Old Dec 16, 2002 | 11:19 AM
Border3899's Avatar
Border3899
Compression Test
Thanks so much for the feedback on this i will attempt the compression check some night this week.
Old Dec 18, 2002 | 01:33 PM
Border3899's Avatar
Border3899
Compression Test
Thanks for everyone's input on this, unfortunately i took my truck into the shop this morning only to find out it's fate, time for a rebuild. Does anyone know of a good reasonable place near MN where i can find one?
