casting number help
Old Mar 23, 2008 | 03:16 PM
63uni351's Avatar
63uni351
casting number help
could one of you good folks help me dechiper my casting number
it is as follows:
d8ve-6015-asa--7615
thanks for your help
Old Mar 23, 2008 | 08:22 PM
doug1222556's Avatar
doug1222556
78 Lincoln engine block. Not sure what the other part # rerfers to. 6015 is block, the other is whatever part you took it off of.
Old Mar 23, 2008 | 11:06 PM
Beanscoot's Avatar
Beanscoot
As has been mentioned in this forum previously, the casting number tells the original vehicle line the casting was destined for, but usually the part is used in other applications also. Thus this casting number is found in the 1978 Mustang II and even marine engine blocks, and probably many others, besides the Lincoln coded by the "V" as the third digit.
The 7615 is probably 7G15, which would be a casting date code. It signifies July 15th, 1977. This is an early date for 1978 production.
Since there was a new 302 casting for 1979 (D9OE-6015), the D8VE is probably a one year type.
Old Mar 24, 2008 | 03:14 PM
63uni351's Avatar
63uni351
lincolns used a 302 in 1978,i thought they only had big blocks in 78
Old Mar 24, 2008 | 04:20 PM
Beanscoot's Avatar
Beanscoot
Well I'm not too sure about all the Lincolns, but the Versaille had a small block.
Old Oct 20, 2011 | 07:39 AM
baddad457's Avatar
baddad457
it is as follows:
d8ve-6015-asa--7615
I know this thread is an old one, but that block is basically the same casting as the 289 Hi-po and the Mexican 302 block. The Suffix should read A3A for these two. The 3A suffix with this casting number is the same block, but with the std main caps.
chukar
Feb 26, 2017 07:43 PM
winggs
1947 and Older Ford Trucks
Jan 4, 2016 09:20 PM
fiftysixfordf250
Nov 6, 2010 01:03 AM
jax1-2
Jun 25, 2004 03:23 PM
beartracks
Jul 18, 2002 06:38 AM
