552ci Engine build ????
Old Mar 22, 2008 | 09:28 PM
jamies460's Avatar
jamies460
Question 552ci Engine build ????
Hello, I am thinking of putting my 552ci engine together myself once the block comes back from the machine shop, I went out and purchased a good torque wrench. I have all the torque specs for the 460ci block. As I have nearly built this car myself, I installed the new 9 inch rear, disc brakes, gearbox, put the 460ci crate engine in.. As Im thinking it cannot be that hard... as when its finished I would like to say I put the whole car together ! I am a perfectionist so I know I will do it right with a little help, any things to look out for... Thanks Jamie.
Old Mar 23, 2008 | 03:08 AM
monsterbaby's Avatar
monsterbaby
just check your specs adn figures closely
Old Mar 28, 2008 | 03:22 AM
jamies460's Avatar
jamies460
One Question I need to ask, as I was going to use a Ford Racing hydraulic camshaft it had 600/620 lift I purchased the cam/ lifters and 3/8 pushrods all together, but I have since sold the cam and lifters, Can I use the 3/8 push rods with the Comp cams solid flat tappet camshaft and solid lifters... Solid camshaft has around 649/641 lift, Thanks Jamie.
Old Mar 28, 2008 | 09:21 AM
monsterbaby
if both are flat tappet cams they should be ok. But did you check VT geometry when you ordered the pushrods to make sure they were the right length? If so then your good to go.
jamies460
19
Jun 7, 2008 10:52 PM
jamies460
13
Mar 15, 2008 09:26 AM
jamies460
Mar 15, 2008 05:52 AM
jamies460
15
Jul 15, 2007 12:10 PM
jamies460
Jul 29, 2006 08:25 PM
