4 Speed Toploader Behind 557ci !!!
Hello, I intend to use my fully reconditioned 4 speed toploader gearbox behind my 557ci , I was out the other day at a mechanic 's shop when I mentioned it to him, the mechanic went on to state that he thinks the Toploader gearbox wont be able to handle the torque of the 557ci engine ! and it will end up blowing up....is this true ??? Thanks Jamie. ( I did tell him that I had the Toploader rebuild- but he still insists it will destroy itself )
from what ive read hes right... there really isnt a good manual transmission option for a 557... it just puts out too much torque. the toploader will work for awhile if you dont powershift, but it will still wear out pretty quick. your best bet is the c-6 auto- anything less is just too short-lived
I used to run small block Toploaders behind a 427 stroker (454) and they held up fine. I don't see why a bigblock Toploader wouldn't hold behind a 557. And I realize that all depends on the actual application as well. Put sticky tires, posi traction and sticky clutches, then dump said clutch at 6 grand, you'll have trouble holding ANY transmission together. I certainly wouldn't be afraid to run a big in/out Toploader behind a 557 on the street.
Thanks Guys, As I do not plan to Rev it to 5 or 6'000 RPM then release the clutch hopefully it will last a while, if it happens to destroy itself I will then replace it with a C6 automatic gearbox. I will run a very thick gear oil ( maybe even straight Lucas ) as thats what the gearbox shop recomended when he rebuilt the Toploader.
This guy is in 'em up to his elbows. I think a proper one will work behind your motor. Check out the toploader/GV combo. 8 speeds, no waiting....
http://www.davidkeetoploaders.com/to...rpricelist.htm
Originally Posted by 79superduty
Im using a a 435np and its behind a 557 now for yrs.is that a top loader or no?i have no problem with it .
Hello 85e150six4mtod, that is a pretty good web-site, as I am in Australia i think my rebuilt Toploader came out from behind a high performance 351ci from a late 1960's or early 70's Ford, as i had to purchase a 429-460 bellhousing , is there any way of telling what i have by the numbers on the Toploader gearbox ?
i was talkin about a toploader from a 65-70 style mustang. i seen them go for up to 1300 bucks today at the swap meet,theres no way i would put them threw that torture when i could sell it so some one that thinks there the best thing since time began and biuld a c-6 or get a richmond for a couple hundred more.as far as in concerd top loaders arnt worth the money
Kees has id charts also:
http://www.davidkeetoploaders.com/idchart1.htm
Look on the left side for site index.
Good luck.
Good luck.
