High Volume Mechanical fuel pump ???
Old Feb 29, 2008 | 01:52 AM
jamies460's Avatar
jamies460
Question High Volume Mechanical fuel pump ???
Hello, is it possible to buy a high volume mechanical fuel pump for the Ford 460ci engine ? As I would prefer to use a mechanical fuel pump in my 552ci build, I have searched Jegs and Summit racing but can only find a 130 GPH fuel pump... any pointers, Thanks Jamie.
Old Feb 29, 2008 | 08:15 AM
kjett's Avatar
kjett
Is there any specific reason why to go with the mechanical? I had to add an electric inline pump to my uncle's 79 150 because if the truck sat for more that 5 days, the mechanical took forever to re-prime and when it did, the fuel filter (one of those clear jobbys) never really "filled up" all the way. I put the electric inline with the mechanical, but back near the tank, and now after he turns the key on, within 2 seconds the filter is full. Not saying that a good mechanical doesn't have it's place, but on your 552ci, it might not give enough fuel for that motor.
Old Mar 1, 2008 | 12:45 AM
jamies460's Avatar
jamies460
Hello,To be honest I just do not like electric fuel pumps... I had one once in a car and it was noisy as hell ! Would a Holley 130+ GPH mechanical fuel pump feed the 552ci ( 600 to 650 horsepower) I did have a look at a Edelbrock Victor serie's 460ci mechanical pump and it states it will feed up to 800 horsepower- so maybe the Edelbrock Victor fuel pump might be the way to go for me, and will 3/8 fuel line be O-K from tank to carb with this engine???
Old Mar 1, 2008 | 05:14 PM
hotrodmerc's Avatar
hotrodmerc
The Mallory elec. pumps are very quiet. I believe the newer Holley pumps are also. These pumps are gerator style pumps the noisy kind is a vane pump.
Like the older Holley red or blue pumps.
Old Mar 1, 2008 | 05:47 PM
Bear 45/70's Avatar
Bear 45/70
Holley makes high volume mechanical pumps, but some 460s don't have the boss or the machining to run the mechanical pump.
Old Mar 1, 2008 | 06:06 PM
Bear 45/70's Avatar
Bear 45/70
Probably not on the Holleys feeding the big CIDs. I had a customer a few years back with a 31 foot offshore racing catarmaran with twin 502 BB Chevies with mechanical Holleys and without the electrics feeding the mechanicals the engine went flat on the big end, above 5000 rpm.
Old Mar 1, 2008 | 08:21 PM
jamies460's Avatar
jamies460
Hello Bear 45/70, are you saying to use both a mechanical and electric fuel pump ??? as that what it sounds like. Do you know of any reasonable priced high volume electric pump, as the ones I have looked at are in the $400 to $500 price range, also what GPH to I need to look for in a fuel pump to feed my 552ci.
Old Mar 1, 2008 | 08:31 PM
Bear 45/70's Avatar
Bear 45/70
Yes, run both and the pumps were Holleys, but I can't remember for sure which ones the electric pumps were, but they were red. Damn, thinking about it that was 1994, no wonder I'm having trouble remembering.
Old Mar 2, 2008 | 08:29 PM
kjett's Avatar
kjett
You can get the Summit electric pump for like $129, with a regulator. It flows 130gph ad 14psi. The summit pump is the same as the Holley "black" pump, just cost less....
Old Mar 3, 2008 | 01:28 AM
Handegard's Avatar
Handegard
Hello,To be honest I just do not like electric fuel pumps... I had one once in a car and it was noisy as hell !..... the 552ci
How do you plan to build a 552ci engine, that'll be so quiet you can hear the fuel pump over it [*grin*]
Old Mar 11, 2008 | 08:57 AM
blown86hallet's Avatar
blown86hallet
James
I'm in the process of building a 588ci 12-71 Blown BBF for my boat, I'm going to use a mechanical fuel pump!!! Forget Jegs, or Summit or anyone else!!
Use a CLAY SMITH FUEL PUMP!!! These guy's have been there done that for years, 140 gph, 14-16 psi (yes you will have to use a pressure reg) can handle well over 1,000 horse power!!! (1,300 gas and 1,100 alcohol)
I got mine it was only $105 bucks.
http://www.claysmithcams.com/
cheers
Old Mar 12, 2008 | 11:11 PM
levi18175's Avatar
levi18175
I'm running an edelbroke in my ranger. It's only a small block, but it sucks the fuel. I called, and told them my build and the sent me a custom built mechanical for the truck. It holds arou 14-16 p.s.i and is rated to flow 140, but I have no way to test it out.
Basically what I am saying, call up the big guys, they are more than happy to build you what you need.
Old Mar 13, 2008 | 02:35 AM
Bear 45/70's Avatar
Bear 45/70
What the h#ll kind of carb or you running to have a needle and seat the will handle 14-16 PSI? Otherwise I'm calling BS on you claim.
Old Mar 13, 2008 | 06:05 AM
hotrodmerc's Avatar
hotrodmerc
No wonder you are sucking fuel. 9 psi is about the most I have ever seen a carb handle. I totally agree with Bear
Old Mar 15, 2008 | 05:52 AM
levi18175's Avatar
levi18175
dual 600's on a 347, It's a nasty little motor. It's an all edelbrock engine, Torker plus cam, performer carbs, performer heads-2.02v, flat tops, blah blah blah. Alot of money, that basically sets and looks purdy. Can't afford to drive it.
jamies460
Aug 15, 2010 03:31 PM
jamies460
Mar 29, 2010 09:00 AM
jamies460
Jun 19, 2007 08:44 AM
jamies460
15
May 17, 2007 10:19 PM
jamies460
18
Nov 24, 2005 10:32 PM
