Fuel pumps problems
Old Mar 22, 2008 | 08:34 PM
JJAPHIPPS22's Avatar
JJAPHIPPS22
Fuel pumps problems
Fuel Pumps run continuesly with key on engine off, and truck wont start.
(91 F-150 5.0) Where should I start.
Old Mar 22, 2008 | 09:04 PM
quicklook2's Avatar
quicklook2
classic sign of bad computer.
Old Mar 22, 2008 | 10:07 PM
Animalistic's Avatar
Animalistic
Either that or the relay is stuck closed. I am not too sure on these models but I have seen relays weld themselfs closed in other applications. Something to check?
Old Mar 23, 2008 | 08:50 AM
stevcher's Avatar
stevcher
fuel pump problems
Try changing fuel filter first.Cheap and easy.They will get clogged and not allow
system to reach pressure to shut down.Had same problem with 92 and changed filter.Good luck.
Old Mar 23, 2008 | 09:23 AM
EPNCSU2006's Avatar
EPNCSU2006
The 2-second operation of the fuel pump at initial key-on is independent of fuel pressure, so a clogged fuel filter will not cause the pumps to run continuously with the key on. There's actually no fuel pressure sensor at all on these year trucks.
Old Mar 24, 2008 | 09:40 AM
JJAPHIPPS22
I am going try the fuel pump relay first, then look into the computer. Also with key on engine off I am getting continues spark could this also be part of the problem.
Old Mar 24, 2008 | 10:34 AM
quicklook2's Avatar
quicklook2
try the relay but it will be the computer.
Old Mar 24, 2008 | 10:48 AM
JJAPHIPPS22
Not trying to offend here, But why do you feel so confident it's the computer?
Old Mar 24, 2008 | 11:17 AM
quicklook2's Avatar
quicklook2
because it is a classic sign of what happens when one goes bad.
another member has a long post about similar problem and he tried everything and it was the computer.
i will find a link for you.
here it is:
https://www.ford-trucks.com/forums/7...ml#post5729854
look at some of his earlier posts to find the original discussion of his problem.
Old Mar 24, 2008 | 12:51 PM
Bad92Nite302's Avatar
Bad92Nite302
hmm *scratches head* that may be the problem with this Nite then... It was the 3rd fuel pump the guy put into it...
Old Mar 24, 2008 | 04:38 PM
EPNCSU2006's Avatar
EPNCSU2006
While it may be the computer, it's still good practice to troubleshoot the rest of the system before throwing in a relatively expensive computer.
Old Mar 24, 2008 | 05:24 PM
Virto's Avatar
Virto
No reason not to check the relay, but like QL says, its most often the ECC.
Old Mar 24, 2008 | 05:55 PM
quicklook2's Avatar
quicklook2
always a good idea to trouble shoot all possible problems.
i hope it is something simpler, or cheaper than the computer.
Old Mar 24, 2008 | 07:09 PM
albung's Avatar
albung
so what ur saying is the truck runs even with key off??? I only say that cause u say it still sparks, and that would sound like ign switch or the rods goin to it
Old Mar 24, 2008 | 08:04 PM
quicklook2's Avatar
quicklook2
key on.
engine off.
is what he said.
