Sponsored by: Real Truck
Emergency! Lift Help Needed
Old Mar 22, 2008 | 07:16 PM
MRyanF's Avatar
MRyanF
Ok first off, I have a 2006 F-250 that I am putting a 6" fabtech basic lift on.
So I have my lift kit and get the front installed (all day, not 3 hr job, BTW) and go to do the rear which is supposed to be u-bolts and blocks and open the box for the rear stuff and its assorted (unneeded) hardware, no blocks or u-bolts! So I have the front done, and am stuck.
Being the weekend, I cant even call the place I ordered the stuff from, but I am going to have to make the blocks and get u-bolts locally because I have to drive the truck monday.
Can someone please tell me how tall the blocks are supposed to be and how long the u-bolts should be? I can guess and probably get very close, but if someone has the kit and could measure, I would really appreciate it.
Thanks,
Ryan
Old Mar 22, 2008 | 11:29 PM
MRyanF's Avatar
MRyanF
Anyone? PLEASE!!!
Old Mar 22, 2008 | 11:37 PM
Nathane's Avatar
Nathane
I think you can rent a compact from enterprise from like $20 a day...
Only advice I can give, srry
~Nate
Old Mar 22, 2008 | 11:57 PM
MRyanF's Avatar
MRyanF
Yeah, thats no help since I drive a truck for a reason. Can't haul much in a compact
Old Mar 23, 2008 | 07:48 PM
MRyanF's Avatar
MRyanF
TTT, I really need help guys, surely someone here has a 6 inch lift and can measure their rear blocks and u-bolts?
Old Mar 23, 2008 | 08:14 PM
jake00's Avatar
jake00
your best bet may be to wait till the place you bought your stuff from opens.
I have no idea where you're going to buy u bolts on a sunday holiday
that said, you should have 2" blocks in the rear. if you're going up 6 n the front, how much do you want to go in the rear?
Lots of people raise the rear less to even out the ride
Old Mar 23, 2008 | 08:19 PM
MRyanF's Avatar
MRyanF
I am just wanting to level it out. So will the 2" blocks and stock springs level it out? And is that adding 2" blocks on the stock ones?
Old Mar 29, 2008 | 10:51 PM
jake00's Avatar
jake00
f350 blocks would level it out
Old Mar 30, 2008 | 01:56 AM
bmvtr's Avatar
bmvtr
I dont think your going to find U-bolts from the auto parts store. my friend tried to find them for his 3"" lift and they were special order. depending on the block height add that to the bolt length then allow for about an inch or so longer then what you need to allow for enough threads to be past the nut. also make sure you figure out the right type of u-bolt you have.
Old Mar 30, 2008 | 05:34 AM
fordf150guy's Avatar
fordf150guy
chock this one up as one of life's little lessons....the parts list might not be such a bad thing to go over before starting any serious mod....hope you have your problem fixed.
villebrunj
2009 - 2014 F150
Mar 1, 2014 05:43 PM
Pappys53
May 26, 2013 06:07 PM
HKusp
29
Aug 24, 2010 11:58 AM
fordman1090
Dec 2, 2009 10:52 AM
Rob.D
Jun 9, 2009 06:50 AM
