4x4 problems
Old Nov 13, 2008 | 08:08 AM
Fishin76's Avatar
Fishin76
The 4H light on the dash will not work if the IWE solenoid is bad also.
Old Nov 13, 2008 | 05:12 PM
tseekins's Avatar
tseekins
Veteran: Coast Guard
Originally Posted by Matt983
I second that. Check the electric transfer motor. Its super easy to change yourself. Check Rockauto.com, it has refurbished ones listed as $141 dollars. I doubt you'll see it that cheap at the local stealership's parts department.
this is what the culprit looks like:
its screws right into the backside of the transfer case. If the motor is fried or the harness is unplugged 4x4 will not work and no indicator lights. Check the harness first. I've heard that sometimes the motors just seize up and whacking it with a hammer then trying to shift into 4x4 works.
Originally Posted by Fishin76
See this TSB. The part in the TSB is ~$30, and will fix your 4x4
https://www.ford-trucks.com/tsb/full...hp?tsb=06-8-15
Fantastic posts guys! My question is: I'm most likely going to get a 2010 F-150 4x4, has this problem been improved upon since the '04's came out?
I drive a an '88 dinosauer and my '04 Expy is a 4x2. Need less to say, I'm unfamiliar with the '04 - '08 generation.
Thanks
Tim
Old Nov 15, 2008 | 07:08 PM
DesertStorm's Avatar
DesertStorm
All these problems is exactly why I got the tried and true pull lever 4x4. If you cant trust the equipment, then why have it? It sure would suck to be mired up in a 3 foot mud hole or in 12" of snow and find out that that little actuator has crapped on you.
Liquid10Rider
Dec 12, 2016 12:40 PM
Rus01
Oct 20, 2016 11:01 PM
therigwelder
1997 - 2003 F150
Jul 23, 2016 01:35 AM
Fkudlack
2004 - 2008 F150
Apr 30, 2016 11:18 PM
Chewy2001
Computer Chips & Tuners
Apr 18, 2007 11:44 AM
