Sponsored by: Real Truck
door seals leaking?
Old Mar 22, 2008 | 12:30 PM
sweet03cobra's Avatar
sweet03cobra
door seals leaking?
Is it common for the door seals to go bad so early. I have a 04 and it sound like I'm riding in a vert half the time. Is this common, I checked them out and they are not cracked or nothing. Anyone else experience this?
Old Mar 22, 2008 | 01:55 PM
adambomb's Avatar
adambomb
my passenger side door was letting in air when driving at highway speeds. it started doing this right after the Dealership did body work on the door after it was damaged on their lot. i took it back to them yesterday and we went for a test drive and they did the "paper test". The paper test is where you open the door then but a sheet of paper in between the door and the truck and shut the door on the paper. if the paper slides out easily when the door is shut then there is a problem. they did this test and adjusted the door until it passed this test. i would say its 95% fixed now but i hate all the bs they put me through so i will just live with it unless it gets worse.
Old Mar 22, 2008 | 10:04 PM
sweet03cobra
what adjustments did they make? I'm sure that is what is wrong with mine. The wife wrecked it while I was in Iraq and I don't remember it sucking wind so bad.
Old Mar 24, 2008 | 10:34 AM
adambomb's Avatar
adambomb
to be honest i have no clue. it only took the body shop guy 30 minutes. i would guess he just banged it with a rubber mallet until it passed the paper test. there were also random shoe prints on the inside of the door so maybe he had to kick it a few times. haha lol. GOOD LUCK
Old Mar 24, 2008 | 11:32 AM
sweet03cobra
oh damn, I can do that Thanks and I will call the body shop to check it out.
Old Mar 24, 2008 | 11:53 AM
Richard_cranium's Avatar
Richard_cranium
Ive got a buddy in Alabama that fixes a lot of these trucks after accidents. He said that due to the size of the door you can actually roll the window down and put your knee or foot into the lower portion and pull the top in and down and the door will bend enough to pass the paper test. I did it with mine and no there is zero wind noise. everything works just fine.
just my $0.02
Old Mar 24, 2008 | 01:20 PM
msgtg's Avatar
msgtg
Steven, would that also work for the bottom? BTW, love the pic Pal.
Joe
Old Mar 24, 2008 | 02:37 PM
sweet03cobra
well I will give that a try, just roll the window down and open the door and just try to bend the top portion down and in ah?
Old Mar 24, 2008 | 02:52 PM
msgtg's Avatar
msgtg
Be gentle! You don't want to have to replace a door!
Joe
Old Mar 24, 2008 | 03:03 PM
sweet03cobra
Yeah, I guess you are right, I will take baby steps. It is pissing me off so bad lucky I don't tear the door off.
Old Mar 24, 2008 | 06:52 PM
msgtg's Avatar
msgtg
Let us know how it goes!
Joe
Old Mar 24, 2008 | 07:31 PM
sweet03cobra
Joe, you air force?
Old Mar 24, 2008 | 09:15 PM
super 6.8's Avatar
super 6.8
Try adjusting the striker first. You can get your door to shut tighter by moving the striker inboard some.
Old Mar 24, 2008 | 11:46 PM
sweet03cobra
Good call, I will try that first. See if that helps. Thanks
Old Mar 25, 2008 | 01:00 AM
aldridgec's Avatar
aldridgec
I wouldn't recommend touching the striker. WHile you CAN get it to shut tighter, it covers up the bigger problem. Over time, from closing the door and just general travel, the tops and bottoms of the doors bend ever so slightly outward. The top is far more susceptible to this than the bottom. It is because the frame is so small around the window and there is nothing holding it in like at the latch area.
The best fix that I have used on many vehicles for wind noise problems is to do what has been suggested. I don't leave foot prints on the door panel though! Roll the window down and gently pull on the door frame with your knee in the door midway. You can tweak certain areas as needed along the frame as well. Be careful. If you get to gungho on some doors they will suddenly give way and you will end up with a creased door and a bigger problem. Go a little at a time.
