Generic oil ??
Old Mar 22, 2008 | 10:54 AM
rouschfan's Avatar
rouschfan
Generic oil ??
This has probably already been asked, but.... Who makes the auto part's store's oil, such as O'Reilley, Napa and so on, I have a 98 ranger that i have alway's used Penzoil 5w30 in, but with the rising price of oil, ( 3.09 a quart the last time i did an oil change ) I am considering changing brand's. Does anyone have any thought's on this subject ?? Thank's
Billy
Old Mar 22, 2008 | 11:36 AM
Dan Robertson's Avatar
Dan Robertson
I too use Penzoil and agree that it is very costly,(even at Walmart) but I still consider regular oil changes with quality oil to be the most cost effective maintenance that one can do. I try cut costs by avoiding unnecessary driving by consolidating trips, drive at reasonable speeds and keep my Ranger tuned up to increase gas mileage but I don't feel that cutting costs by swapping to a cheaper brand of oil is really saving money in the long run.
Old Mar 22, 2008 | 02:15 PM
BuffmanLT1's Avatar
BuffmanLT1
autozone has $13.99 oil change specials all the time. Fram isn't the best filter, but if going 3k oil changes they are just fine.
Old Mar 22, 2008 | 02:45 PM
gbadgley's Avatar
gbadgley
If you read the fine print you can figure out who refined the oil. The refiner's address is on there, but it is most likely an offshoot corperate name. Greg
Old Mar 22, 2008 | 03:31 PM
BuffmanLT1's Avatar
BuffmanLT1
Supertech from walmart is a decent oil. just watch for oil to go on sale. I've gotten mobil clean 5000 before for $8.99. 5 quarts and an STP filter.
Old Mar 22, 2008 | 04:24 PM
Ford_Six's Avatar
Ford_Six
I run mostly Supertech oil, or Castrol.
Lots of generic oil is made by the parent company of Valvoline, Ashland Oil.
Old Mar 22, 2008 | 04:34 PM
pgw85706's Avatar
pgw85706
I was at NAPA yesterday and asked this question. Valvoline makes the NAPA branded motor oils.
Old Mar 22, 2008 | 04:53 PM
khadma's Avatar
khadma
Carpenter Local 745
Supertech is from Walmart, correct?
I use Castrol in all my trucks except the 07 Explorer = Motorcraft senblend from Walmart and my 88 Mazda gets Cheap 30 weight from Checker, but I may switch to a cheap Walmart brand on next change - The OEM filter is 11.00 - OUCH!
Old Mar 22, 2008 | 07:41 PM
rgp's Avatar
rgp
Price of motor oil
Rather than thinking that an expensive motor oil is a better motor oil, I read the fine print on the container to verify that the oil's specifications satisfy my engine's requirements. The American Petrolium Institute (API) has developed standards/specifications that must be met or exceded by motor oil manufacturers.
Check the "S" designations, I.E.,...SF, SG, SJ, SL....etc., to see if you're getting something in the costly oil that you are not getting in the less expensive oil.
I have yet to find any appreciative value in an expensive motor oil.
Old Mar 22, 2008 | 07:57 PM
Econoline 150's Avatar
Econoline 150
I have a stack of Quaker State oil filters I got for dirt cheap, wonder who makes them and STP filters ?
As for the Wally World brand oil, Ive heard its pretty good stuff.
Old Mar 22, 2008 | 11:21 PM
BuffmanLT1's Avatar
BuffmanLT1
Last time I checked all motor oil carries API certs, otherwise you shouldn't buy it. Latest Cert is SM rated oils.
IF you change your oil every 3000 miles, no real need to buy any "expensive" motor oil. But for people who beat on their cars, want Extended OCIs, or want the lowest wear possible is where the more expensive oils come into play.
Old Mar 23, 2008 | 09:27 AM
sfcwoodret's Avatar
sfcwoodret
I've got to pay for Castrol GTX because it's just worth it.
Old Mar 23, 2008 | 10:26 AM
wendell borror's Avatar
wendell borror
I run mobil 1, it was allready high, so price isn't an issue. The oil is the life's blood of a truck, not the place to srimp. I'm a big beliver in synthetic fluids, less heat and wear, better mpg and they don't have to be changed as often.
Old Mar 23, 2008 | 10:34 AM
jimdandy's Avatar
jimdandy
I run Super Tech synthetic. 10k oil changes, or yearly, depending on the vehicle. If my trucks were used in heavy duty apps, I would use the same oil, but change it a little more often. jd
Old Mar 23, 2008 | 10:35 AM
rgp's Avatar
rgp
Contaminated motor oil
My understanding of motor oil is that it does not wear out. As long as it includes the appropriate API certs it suffices. We change our motor oil because it gets contaminated. As soon as an engine is put into service, moving parts that are seperated by a film of oil shed microscopic sized particles that become suspended in the oil. Carbon contaminants from the combustion chamber also end up suspended in the oil. Sulfids, H2O, and hydrocarbons (acids) also end up suspended in the oil. None of these resident suspensions are of any value to an internal combustion engine. That is why we need to change the oil at specific periods. The frequency of oil changes, time or miles, is a function of how we operate our engines. The API certs are of more value to a oil purchase decision than the price of the oil.
