oil behind the engine, line?
Old Mar 28, 2008 | 01:40 AM
TTFord07's Avatar
TTFord07
Im not really sure, i cleaned around the oil pan and ran a bead of high temp gasket maker around it, seems to have helped alot, almost completely, im gonna get back under it and put some on the back curve of the pan.
Old Mar 28, 2008 | 09:27 AM
powerstroke1869's Avatar
powerstroke1869
hmm maybe thats something i need to try ttford..i have an oil leak that i cant find for the life of me.. ive done the ccv mod no oil on the hpop just replaced my turbo ped o-rings...the oil drips down the backside of the oil pan and drips off my fumoto drain valve its really pissin me off
Old Mar 28, 2008 | 10:01 AM
jwhitetail's Avatar
jwhitetail
I used to vent my CCV all the way to rear and it was never cloged but caused mysterious oil leaks, hose now run straight down and out through fender well, on drivers side. Oil leaks quit!
Old Mar 28, 2008 | 12:39 PM
powerstroke1869
hmm i might have to try cuttin it out right below the steering counsel
Old Mar 28, 2008 | 01:55 PM
TTFord07's Avatar
TTFord07
Ya that misterious oil leak sucks, Its not my main seal cuz it looks clean, I put a short peice of hose just goin right beside the tranny. Im gonna take a beeter look at the pan this weekend, I really dont want to pull my engine but prolly will.
Old Mar 28, 2008 | 04:57 PM
rebelchevy02's Avatar
rebelchevy02
Mine actually started leaking in the same spot, but mines leaking some from the HPOP. Sounds like a terminator might be in order.
Old Mar 28, 2008 | 08:38 PM
TTFord07's Avatar
TTFord07
Whats that? I really dont know to much about those, oil pump right?
Old Mar 28, 2008 | 08:44 PM
rebelchevy02
yeap, HPOP = high pressure oil pump. Its what feeds high pressure oil into your injectors.
Old Mar 28, 2008 | 11:04 PM
TTFord07's Avatar
TTFord07
No i was talkin about the terminator thats a brand name right? I think i need a new oil pan seal to be honest, but its freakin snowin again outside, so in calving season I dont have time to really tear into it at the moment.
Old Mar 28, 2008 | 11:33 PM
rebelchevy02
Ooops, my bad, yes the terminator is a brand name, but its acutally an HPOP, a dual HPOP. Hes got a nice setup using two oem pumps. Joey is the contact, and I think he also owns the company.
