Holley carb
Old Mar 21, 2008 | 06:42 PM
Kothlow's Avatar
Kothlow
Holley carb
Does anyone know what this carb is or where I can find out? I just want to know the cfm and what kit to buy. Holley E3ZE-9510-BGA List# 50117 3052
I tried to research it, and all I got was that it was originally off an early 80's 302 HO. He claims it didnt need a rebuild and was running great, but after getting it home I think I was suckered haha.
Old Mar 21, 2008 | 09:31 PM
Kothlow's Avatar
Kothlow
Also I have a .512 lift cam, I was wondering what rockers and springs you guys would recommend using so I have good clearance. I was looking at 1.6 rockers and springs good to .550 lift
Old Mar 21, 2008 | 10:33 PM
doug1222556's Avatar
doug1222556
I can tell you the carb is off an 83 Ford, but not much more. Once you cam up ,it's probably going to be too small anyway, even working right. Sounds like the right stuff, otherwise.
Old Mar 22, 2008 | 10:59 AM
mark a.'s Avatar
mark a.
Can you post a picture of it ?
Old Mar 24, 2008 | 09:54 AM
Mike G's Avatar
Mike G
I like this little web-site, it has been pretty useful and has additional links. Since you didn't mention if it was 2 or 4 brl, you will need to investigate on your own...
http://www.mortec.com/carbs.htm
--Mike
Old Mar 25, 2008 | 01:56 PM
Kothlow's Avatar
Kothlow
Thanks for all the help guys, I found out it is actually of an 83 mustang, and is a 600cfm. They are fairly easy to get kits for. Thanks again!
Old Mar 25, 2008 | 06:37 PM
doug1222556
That might work, depending on the heads and intake you are running. It's actually a little more CFM than I expected. It's a perfect starting point, though. If it doesn't breathe enough on the top end you can always go a little bigger.
Old Mar 25, 2008 | 07:17 PM
Kothlow's Avatar
Kothlow
The intake is a aluminum single plane, nothing too serious. I'm soon ready to put it all together, the heads otherwise are just stock valves, along with a set of headers to top them off. I'm using just stock pistons, new moly rings of course.. thinking about downsizing the cam. any thoughts? I'm not looking for a powerhouse, I just want something to push my 35's along a little better. I rarely carry a heavy load.
Old Mar 25, 2008 | 07:18 PM
Kothlow's Avatar
Kothlow
oh and also I've already got 4:11's front and back just incase gears are suggested
Old Mar 25, 2008 | 08:38 PM
doug1222556
Well from everything you've said you should be good. The problem with the cam is, that all we know is the lift. That's like saying " are 36 c' s " good. On a 5' 9" 110 # blonde 18 year old, I'd have to say yes. On a 375# 60 year old, not so much. It seems like a lot of cam to me for what you want, especially if the duration is in line with most off the shelf grinds. Duration= age and weight, if those are low, you may be alright. How about the giving us the rest of the specs?
Old Mar 25, 2008 | 08:45 PM
Kothlow's Avatar
Kothlow
yeah sorry never thought. 230 duration @.050 I believe it is. It is a cam from Comp. btw your references gave me a chuckle ha
Old Mar 25, 2008 | 10:38 PM
doug1222556
Yeah, were mot talking 18 year old anymore. It's not stupid big, but probably a bit more cam than you want for low end torque. Correct me if I'm wrong-( don't worry 2 or 3 of these guys will), but you should step back down to an RV cam. You didn't mention any mods to your heads, and a cam like that won't do anything from 0- 30 or 40 mph and not really kick in untill 60mph + with your set-up. Is that what you want?
Old Mar 26, 2008 | 11:03 AM
Kothlow's Avatar
Kothlow
well, basically i'm trying to get some more power on the highway with my 35's, it has plenty of low end because of the 4 speed granny and gears. So i'm thinking that is what I want, but I dont want to lose any torque either.
Old Mar 26, 2008 | 07:15 PM
doug1222556
It's not like you lose torque, it just comes in at a higher rpm. If you feel it's really strong at the low end, then you are probably fine, but you are going to lose some low end. In some ways a cam is like a checking account, you can write a bigger check to one place, but it leaves you less money for the other.
Old Mar 30, 2008 | 02:19 PM
hojolabo's Avatar
hojolabo
Intake
I could be wrong and am definately no expert, but I believe a single plane intake is for a hi rev engine and isn't a good choice for what you want. I'm in the process of de-building a 351W, 475 hp down to a 350hp low to mid power band and was told to remove my Victor Jr.single plane to a dual plane, both 4v carb.
Just keep asking ?s on what your desire is and you will get the answers.
BTW I got my 351W in a swap and knew what I was getting as far as a Hi performer. The engine had just been built and never run when I got it and I'm still asking ?s and making changes.
It will end up in my 92' F150 SWB e4od 4X4.
Oh yea I have a 78' F350 dually, 351M stroked to a 400 ci and have a low to mid range cam, stock heads, a 2v carb, 4sd granny, single in, dual out Flo master and I get 13-14 mpg and love the performance. I believe I have pic in my gallery. It's a daily driver, summers only.
Good Luck & keep asking ?s be fore spending $$.
