weird shifting problem
Old Mar 21, 2008 | 03:19 PM
Raider50's Avatar
Raider50
My 97' 460 auto F250 has some shifting issues. On the gear selector if you ever go past drive into 2nd or 1st and then once you go back into drive it wont shift out of 1st some times or it will shift but it will only shift into second. But it dose **** eventually after gasing it and then letting off, it might just take 7 or 8 trys to shift. It dosnt matter if its summer or winter it has happened at both times of the year, it is nothing major but it is majorly annoying. Any thing helps thanks guys
Old Mar 21, 2008 | 07:51 PM
mhg's Avatar
mhg
go here www.fordfuelinjection.com
go to down load files and look for the MLPS info
this sounds like you have a bad mlps
and they have the test procedures
Old Mar 21, 2008 | 08:03 PM
Raider50's Avatar
Raider50
sorry im a major newbie still whats a mlps?
Old Mar 22, 2008 | 03:51 PM
fast70's Avatar
fast70
hey i solved the problem hope this helps you my truck was doing the same thing and i did some research and found out that on that tranny the nuetral safety switch as auto zone calls it tells the tranny when to shift so i changed that and now the truck shifts smooth and perfect its a 37 dollar part
Old Mar 22, 2008 | 05:12 PM
Raider50's Avatar
Raider50
alright thanks ill look into the switch
Old Mar 22, 2008 | 07:53 PM
mhg's Avatar
mhg
manual lever position sensor
dangerusty
1983 - 2012 Ranger & B-Series
Mar 3, 2012 08:28 AM
rcraig
Feb 4, 2011 12:54 PM
turbofal
Mar 9, 2009 09:40 PM
Meat_fire
Feb 2, 2008 06:02 PM
Meat_fire
Jun 6, 2003 04:44 PM
