fuel lines?
Old Mar 22, 2008 | 12:49 PM
codybakken's Avatar
codybakken
fuel lines?
I am instaling a fule injected 302 from a 93 into my 65ford. i am in the process of adapting the 302 to the 65 frame. i dont know much about these newer vehichles but thats what this site is for right? the 93 has a rear tank and a side saddle tank each has 3 lines coming off it. what are these for? i assume one is a vent line and atleast one other is for taking gas to the engine.
i apreciate your help
im gunna need ALOT!!!!!!
Old Mar 22, 2008 | 05:55 PM
netscaner's Avatar
netscaner
Yes, one line is a vapor line, the one from the top of the tank.
And one of the other two is the pressurized fuel being pumped from the tank (you will probably have to get an in tank high pressure pump) and the remaining is for the excess fuel from the fuel pressure regulator which you will have to install. which is returned to the tank.
I am assuming you are going to keep the 302 fuel injected.
You will need the computer that was used with the engine.
Old Mar 22, 2008 | 08:23 PM
codybakken's Avatar
codybakken
thank you
ya im keeping the fule injection i just hope i can make it work. i have the whole wiring harness the computer basicly the whole truck and all in exchange for levleing 50 yards of gravel how's that for a deal
