Chip Back... Still problems, thinking VB or TC??
Old Mar 24, 2008 | 07:49 PM
  #46
Todd525's Avatar
Todd525
If you had a edge evo, you could look at your line pressure....LOL Trade for your tw chip so you can see whats wrong????LOL
Old Mar 24, 2008 | 07:51 PM
  #47
Robbgt's Avatar
Robbgt
Hahah no thanks! But! a buddy of mine has an edge evo, you can look at like pressure from that? Joe/Bill/Tim, will that work for what were trying to do here? or do I need an actual gauge?
Old Mar 24, 2008 | 08:14 PM
  #48
tjbeggs's Avatar
tjbeggs
an actual mechanical gauges will be best. the Evo will show what the EPC system see's for pressure but that could be part of the problem. The pressure that the system see's could be wrong and part of the problem. we need to see the pressure that is actually being produced.
Old Mar 24, 2008 | 08:15 PM
  #49
tjbeggs's Avatar
tjbeggs
you need a gauge that will read up to 200 psi minimum.
Old Mar 24, 2008 | 08:35 PM
  #50
c00nhunterjoe's Avatar
c00nhunterjoe
you need the gauge definatly, that way you can see what is going on both before and after you send it into limp mode.
cross one bridge at a time, as for the chip, i would think you want the typical tw trans tunes. the stock pressures are probably part of your flaired/slipped shifts but there may be more issues.
Old Mar 24, 2008 | 10:37 PM
  #51
Robbgt's Avatar
Robbgt
Joe, it was having the issues before with the TW standard tunes, and that's why I sent it back for the re-burns. It's better now than it was before but the problems are still evident
-Robb
Old Mar 25, 2008 | 08:16 AM
  #52
MADVAN's Avatar
MADVAN
Robb
You have to check the line pressures in all gears at idle.(trans warm)
If low donot stall test.
If it passes with good line then move to the stall test.
Let the trans cool some between each gear test.
Note the stall rpm and pressure. This will help pinpoint the issue if any.
Bill
Old Mar 25, 2008 | 03:44 PM
  #53
Robbgt's Avatar
Robbgt
Alright Thanks bill. What exactly do I need to build gauge? Where will I connect it? What type of hose? Fittings? Can I get this at local NAPA or Parts shop or do I need something specialized? Thanks!
-Robb
winfordr
Mar 7, 2016 08:37 PM
Dmntxn77
Apr 29, 2012 07:48 PM
cbakker
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Feb 7, 2012 11:49 AM
tjbeggs
15
May 29, 2011 07:48 PM
ernesteugene
22
Mar 13, 2007 02:48 AM
