Headlight Relay System
Old Mar 21, 2008 | 07:15 AM
FXDC4419's Avatar
FXDC4419
Does anyone have a part# or source for the relays in the tech article on this subject by Erik Marquez? The DPST relays seem to be rare (Dual Pole Single Throw) Or how to contact Erik.
Thanks For any help.
Bill T.
Old Mar 21, 2008 | 12:25 PM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
FXDC 4419
https://www.ford-trucks.com/article/...ay_System.html
Theres also an article here if I remember right it is called
Brighter Brights,and Whiter Whites you may search for these words?
Wally Womack
Old Mar 21, 2008 | 12:44 PM
66sprintw53's Avatar
66sprintw53
Bill
I think you can use a standard Bosch type relay for this (SPDT). The diagram shows the current flowing out of the relay to the headlights from 2 seperate terminals on the relay (low beam relay blue wire, high beam relay pink wire). You can use a standard Bosch relay and just connect both wires to the terminal marked 87 (light normally off until you activate the relay then it is on).
Very common relay, most cost less than $10.
http://www.partsexpress.com/pe/showd...number=330-070
This site gives a good basic description of how it works.
http://www.bcae1.com/relays.htm
Chris
Old Mar 21, 2008 | 12:52 PM
Pro-Street/StateTK
FXDC4419
heres a link
https://www.ford-trucks.com/article/...r_Brights.html
Wally Womack
Old Mar 21, 2008 | 02:09 PM
FXDC4419's Avatar
FXDC4419
Thanks guys, I kind of thought it could be done that way but was afraid I might be over looking something. You know kind of like not being able to see the forest for the trees. I know I am probably the only one who has ever had that problem, LOL.
Thanks again.
Bill T.
erik68
24
Oct 15, 2019 03:05 PM
F2Erik
29
Apr 11, 2016 01:34 AM
Erik Jaeke
Sep 21, 2015 10:44 AM
thatguy91
New Member Introductions
Mar 17, 2015 01:18 PM
erik68
15
Jan 30, 2015 04:23 PM
