Oil Sludge
Old Sep 19, 2015 | 04:54 PM
Erik Jaeke's Avatar
Erik Jaeke
Oil Sludge
Changing the oil in my 1979 400cu. I can see a ton of sludge inside the valve cover. Best ways to clean it? Thanks!
Old Sep 19, 2015 | 06:08 PM
Blue and White's Avatar
Blue and White
Best is to pull the VC's and clean it out with rags/shop vac. Plug the oil return drains first so no chunks drop down. Run for 50-100 miles then change oil again with high detergent oil like diesel engine oil. Change frequently after that (eg every 500 miles) for several changes to finish cleaning.
Sludge can be caused by extended oil changes, incorrect thermostat (180 minimum, 190-195 preferred), PCV inoperative or short trips especially in cold weather.
Old Sep 19, 2015 | 06:34 PM
HIO Silver's Avatar
HIO Silver
... also caused by a dusty conditions and a lack of air filter oil/oil filter changes... generally referred to as crummy maintenance practices.
Old Sep 19, 2015 | 06:48 PM
Erik Jaeke's Avatar
Erik Jaeke
Thanks guys. Just bought it.... It had been sitting for 5 years. Trying to get her going
Old Sep 19, 2015 | 07:05 PM
Erik Jaeke's Avatar
Erik Jaeke
Can I use solvent to help clean?
Old Sep 19, 2015 | 07:35 PM
HIO Silver's Avatar
HIO Silver
Yeah but plug the oil return holes and you'll need to clean up all the big chunks that are dislodged. I think hot runs and frequent filter changes would be a better approach at this point. Change the oil and then just change the filter after 100 miles. Top it off and repeat. Monitor.
Old Sep 21, 2015 | 10:44 AM
Erik Jaeke's Avatar
Erik Jaeke
Yeah agreed. I will replace gaskets on both VCs, (after cleaning the inside of both VCs). Oil up, drive for a while, then change oil again. Should help. The motor runs really clean right now, so that's good at least!
Thanks all
Fefanatic
Feb 5, 2018 03:12 PM
fmuguira
Sep 1, 2017 08:06 AM
Shawn MacAnanny
16
Feb 4, 2017 10:58 AM
CheaperJeeper
48
May 22, 2009 08:05 PM
priley
Oil & Lubrication
Sep 17, 2001 07:46 PM
