if you break an axle shaft or hub you can still make it home. I wouldnt drive much though or you could mess up the spindle.
Chromo shafts and real good u joints for the 44 will cost you $800-1000 which is in the neighborhood of what a kingpin D60 will cost you but 99% of the time it will need a complete overhaul.
well atleast i have another complete axle assy in my donor a 79 f-150 sc just have to switch it outand use the 8 lug spindles and hubs if they survive.
Shafts and hubs are exactly the same. Just swap that out if you break something.
to my knowledge the ONLY things transferable from a 44 to a 60 is the brake callipers rotors tie rod and drag link.
You will need to re-gear the 60 with front 60 components. Rear 60 stuff is not interchangable.
If you are not a avid wheeler some good chromo shafts and u joints might be better/cheaper for you.
superior axle shafts and CTM joints are the best and both carry "if you break it we'll replace it" warranties. Expect to pay $800-1000. Id also upgrade to Warn premium hubs because they are stronger than ford stock ones IMHO.
well like i said i have had the d44s' before and havent had any trouble but never had that big of tire before. guess if it grenades i replace it. i have done alot of muddin and thats mainly what i will be doing with it. if anyone will find out what it is capable of it is me cause i only know one way to mud run and that is WIDE OPEN!!!
