Ditching the Catalytic Converter
Old Mar 19, 2008 | 07:29 PM
cauchy's Avatar
cauchy
Gentlemen:
I live in NE Florida and have a 1997 Powerstroke, 18 MPG. I am thinking about removing the catalytic converter, for the sake of the environment, don'tcha know.....the cat converts pollutants to carbon dioxide. Can't have that!
Now, I do not weld, so will an exhaust shop do it for me? And how many more MPG will it give? I am thinking less than one.
Thanks,
James
Old Mar 19, 2008 | 08:11 PM
kawa's Avatar
kawa
Good thinking but it has been said that it helps the exhaust flow more free.
If you so desire a replacement pipe can be purchased on line. Just remove the cat and insert pipe. tighten clamps and viola, no more C02.or kitty
Rog
Old Mar 19, 2008 | 08:19 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Check here for a cat delete test pipe ($47.99): http://www.dieselperformanceparts.com/products.cfm
Look under Ford Powerstroke (on the left), then Year, then Exhaust Products, then 1994-97 Ford Powerstroke Down Pipe and Test Pipes, then Delete/Test pipes.
Old Mar 19, 2008 | 08:39 PM
cauchy's Avatar
cauchy
Bolts
Gentlemen:
The bolts have been on quite a while. What is the best way to go at them besides the obvious - liquid wrench, torch heating and cooling, etc?
James
Old Mar 19, 2008 | 08:41 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Sawzall?????????
Old Mar 20, 2008 | 07:39 AM
Neal 97 250's Avatar
Neal 97 250
Grinder????????
Old Mar 20, 2008 | 01:43 PM
kawa's Avatar
kawa
Well, you said that you don't have access to many tools so you might consider getting "Cat delete Pipe" and then going with your original thought of having a muffler shop install it for you using clamps not welds.
If you go this route and the shop will do it then if for some reason you want to replace the kitty the replacement will be that much easier.
Rog
Old Mar 20, 2008 | 02:04 PM
alstieg's Avatar
alstieg
save the cat and sell it for scrap. that will give you over 100 to spend fixing it up.
Old Oct 27, 2008 | 04:31 PM
maverick1701's Avatar
maverick1701
How difficult is the whole process? It seems fairly simple...saw out the kitty, slide in the new pipe and clamp it down. Is that it? Surely it can't be that simple....
Old Oct 27, 2008 | 04:58 PM
79_250RangerLariat's Avatar
79_250RangerLariat
Even though it's more costly to get maxium effect find/buy a sawzall and get a turbo back 4" system. You'll be glad you did, besides you can never have too many tools
Old Oct 27, 2008 | 05:03 PM
952X4's Avatar
952X4
Turbo back is the way to go, sure glad I did it that way...
Old Oct 27, 2008 | 05:47 PM
maverick1701
eventually that is my plan...3in (maybe 3.5) DP to 4in exaust
houtg
Apr 19, 2015 05:01 PM
RIKIL
Exhaust Systems
Jun 15, 2013 03:23 PM
gblaz123
Aug 8, 2012 07:46 AM
Fairlane62
1997 - 2003 F150
Apr 3, 2007 11:35 PM
