UPDATE: Sway Bar Kit from Summit
Old Mar 19, 2008 | 03:16 PM
FitchBanjos's Avatar
FitchBanjos
Guys, I installed the front sway bar kit from Summit today on my 66 F100 and let me tell you, it is a night and day difference. Not even the same truck. The roll is gone on curves and corners and, it has a more solid feel on the highway. It may be my imagination but, it seems to brake easier also. It may not be diving as much when the brakes are applied. I highly receommend this or any front sway bar upgrade for thr 65-66 F series trucks. It was easy to install too. 6, 3/8" holes and about an hours time and it was done. Well worth my peace of mind should I have to make an evasive move at highway speeds.
Old Mar 19, 2008 | 03:36 PM
judi48's Avatar
judi48
Cool, did you take any pictures of the installation for the rest of us to see?
Judi
Old Mar 19, 2008 | 04:01 PM
FitchBanjos
Here you go..................
Old Mar 19, 2008 | 04:48 PM
matt2491's Avatar
matt2491
Very nice Banjos. I wonder if they carry something like that for the '61-64 straight I-beam w/ leaf springs' trucks.
Old Mar 19, 2008 | 04:51 PM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
Fitchbanjos
Nice job! Looks good also, you may want to give the part number, and maybe
a quick write up for the Articles/Specs area!
Wally Womack
Old Mar 19, 2008 | 05:12 PM
64fordf100292's Avatar
64fordf100292
ya know, from the looks of that sway bar, that might work on a 64 ford with the solid axle. just flip it round so that the the end links got to the frame not the axle.
Old Mar 19, 2008 | 05:14 PM
FitchBanjos
Here is the link to kit I used. It states tht it is for a 66 only but, It might work for a 65.
http://store.summitracing.com/partde...5&autoview=sku
*Another benefit that I just noticed is that you dont hear that damn fuel level sender slapping around inside the fuel tank eveytime you turn a corner.
Old Mar 19, 2008 | 05:19 PM
judi48's Avatar
judi48
Boy that is pretty. I have to pull my front end apart this weekend to put in the radius arm bushings, so I'll check to make sure I'll have the clearance. (LOL, shouldn't be a problem since we're sorta driving the same truck.)
Thanks for posting the picture
Old Mar 19, 2008 | 06:05 PM
rusbukt's Avatar
rusbukt
I want one ! Can you flip those long bolts up so they wont hang up on something?
Looks nice. Like it should be there.
Old Mar 19, 2008 | 06:21 PM
FitchBanjos
The bolts you see pointing down are actually one U-shaped bolt and it cannot be flipped. The threads that are past the lock nuts can be cut off and that is what I am going to do to mine. I do think that you could use 3/8 bolts instead of the U-bolt and install them with the nut on top. I just used what was in the kit per the instructions.
Old Mar 19, 2008 | 06:30 PM
FitchBanjos
Oh wait. If you are talking about the 2 long bolts that the bushings are on, no, they cannot be inverted becasue they would hit the bumper stops on bumps. The clearance is pretty tight in that area. If I cut those off, it is going to be bear replacing those bushings in the future. I will take another look to be sure though.
Old Mar 19, 2008 | 07:17 PM
rusbukt's Avatar
rusbukt
Well you sold me. I'm gettin some. That sender in tank drives me crazy also.
I'm thinking if a guy took a fine tooth hack saw to cut them down. You shouldnt have a prob. gettin them off later.
Very cool product.
Old Mar 19, 2008 | 07:22 PM
matt2491's Avatar
matt2491
Are you kidding me? I shorten bolts by hacking through them with a sawzall like its nobodies business... And the nuts still turn on fine.
Old Mar 19, 2008 | 07:29 PM
FitchBanjos
Well, I was talking about the compression factor of the 4 bushings. if you cut the bolt off flush with the nut, you will have hell getting new bushings on later.
Old Mar 19, 2008 | 07:35 PM
matt2491's Avatar
matt2491
How much is left off the end of the bolt without the bushings compressed but with the nut on?
I don't think it's going to snag up on anything on the road anyway. They don't stick down THAT much...
