UPDATE: Sway Bar Kit from Summit
Old Mar 19, 2008 | 07:36 PM
FitchBanjos's Avatar
FitchBanjos
One other tip. Dont try to center the bar perfectly between the frame. There are clearance issues at the springs, mounts, and bumpers. I had to shift mine 1/2" to the drivers side and it still touched the edge of the spring bumper on that side. Shouldnt be an issue but, you definetly want to clamp the L brackets to the I-beams and use tie straps to mount the bar to the frame and do a mock up of everything and get someone to bounce the front end to see if anything hits.
Old Mar 19, 2008 | 09:43 PM
Bill W's Avatar
Bill W
That is a Great Tip!!! and as soon as I can... I'm gonna order one for my 66.
AND I sent you REP!!! Thanks!
Old Mar 19, 2008 | 11:35 PM
twin66's Avatar
twin66
well i picked myself up one of those sway bars last spring, and its been sitting in the cab since then. This summer im doing it up right so i will install it then. I cant wait now!
Old Mar 20, 2008 | 10:44 AM
airharley's Avatar
airharley
I just did a little checking of the CPP site and they list the same sway bar for both Chebby and Ford trucks 55-59, CP12030 for stock axles. To be honest the solid I-beam axles look to be the exact same between 58-64 so there is a possible option. Give CPP a call to see what they diamentions are of the arm length and width of the mouning holes to see if it fits in your frame rails and clears the springs.
Old Mar 29, 2008 | 07:12 PM
discochris's Avatar
discochris
I just installed mine, and it really does make a big difference in the ride and steering!
Thanks for the pictures too - it made it a lot easier to understand, because the directions that come with it really stink!
shroomopolis
21
Aug 12, 2011 07:20 AM
crazed87bronco
Jun 22, 2011 12:49 AM
notyettoday
Jul 13, 2008 11:06 PM
HardFordCore
Aug 16, 2003 08:27 AM
Don
Dec 8, 1999 05:11 AM
